Help me with my headlights please
Old 09-29-2019, 04:36 PM
oak.tl's Avatar
Unhappy Help me with my headlights please
First post, so here goes. I'm the 3rd owner of a 2001 Acura TL. The passenger's side headlight only worked sometimes. I replaced the bulb, no change except the headlight was brighter when it was on. I now know it's most likely the ballast, so I bought a replacement one. I have the tools to do so, but I have no idea how to take out the headlight assembly on a 2001 Acura TL. There are NO tutorials for the 2001 model year, and 2002 models have the assembly attached to the bumper I believe. I spent a morning removing it to learn I had just made no progress. If anyone has a link to a video, diagram, or explanation, it would be much appreciated. Thank you.
Old 09-29-2019, 05:29 PM
Received 16,260 Likes on 11,971 Posts
all modern cars are pretty much built the same way, ie; drop the front bumper to access headlights
Old 09-30-2019, 02:26 PM
Arkady's Avatar
Two bolts up on top of the headlight, and a few more on the bottom with the head facing the outside of the car. You'll need to drop the front bumper to get to those ones.
Afterwards, unplug the wires at the back and the headlight comes out! Ballast is mounted on the bottom with some big phillips screws.
Old 10-01-2019, 11:59 AM
Avant Garde Wheels
jjashaa's Avatar
almost... my old Genesis Coupe, I was able to pull off the headlights with just two bolts up top.
for the OP, there should be a few bolts that also hold the bumper bracket that also sandwiches over the headlight brackets. my 03 had one on the fender sides and two towards the middle of the car. Just follow the bracket under the headlight.
Old 10-09-2019, 10:51 AM
USAF Veteran
Saudade's Avatar
Although this says 2003, I think it's the same for our 2001s. You may want to get some replacement push clips before you begin.
Remove the front fender:
Change the Ballast:
whitetiger5 (10-10-2019)
Old 10-10-2019, 12:14 PM
7th Gear
Pedro Valdiviezo's Avatar
Yeah there are a good amount of youtube videos for a lot DIY projects for your car.
greenmachine11235
03-07-2018 11:46 AM
Silvaz
06-21-2015 11:58 AM
Luketic
07-17-2013 12:13 PM
edgalang
01-29-2005 08:57 PM
Quick Reply: Help me with my headlights please
