help with KONI shocks
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
I want to purchase the shocks
Does anyone know what the part number is for the Koni shocks that fit the 2000 TL?
Also, my friend told me i only needed a camber kit for the front two wheels for my lowered TL. Is this true?
Thanks guys!
Thanks guys!
I don't know the part number but you can probably ask Snook. He sells them. Go check it out in the Price page.
Camber correction kit is required when you have negative camber that can not be corrected back to within factory spec. This depends on how much your lowered your car. Most ppl on this board have lowered their rides with Comptechs and they say they didn't have to use Camber kit.
Y2K silver TL, non-navi
Factory style full body kit + spoiler
38% window tint
Valentine 1
38% window tint
Valentine 1
Thanks guys!
Thanks guys!
Originally posted by Rice1304:
get the shocks and camber kit for all four wheels. all four of my tires show uneven tread wear even after drop and alignment.
38% window tint
Valentine 1
I dropped mine with H&R
1.75 Inch front
1.5 Inch back
1.75 Inch front
1.5 Inch back
You should first go to an alignment shop and have them align your wheels back as close to the factory spec as possible. If it is determined that it can not be aligned back to within factory specs, then you should consider getting the kit.
Some ppl don't mind the neg camber cuz you can take those corners real fast... but if you don't want to invest too much $$ on your tires, then I'd recommend you to get camber correction kit too.
38% window tint
Valentine 1
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
