Help...headlight removal
No offense but you may be hard pressed to get that information from anyone here. There has been a bad rash of people that own cars with HID headlights getting their lights stolen to be used in cars that don't otherwise come with them. That or they get sold on eBay to people that have had them stolen themselves. The amount of damage done when they get stolen easily runs into thousands of dollars (units themselves, damage to bumpers, hoods and fenders, re-painting).
Like I siad, no offfense, but it's a very sensitive subject.
6th Gear
Thanks Tom. I didn't realize that was such a problem, now I know.
In short, I was slowly pulling into my garage, the a/c kicked on and the car lunged forward, running into my bike rack and pushing the headlight assembly in slightly.
If anyone would like to offer any help through a PM, email, telecon, etc. I would gladly show proof that I am a TL owner and do honestly need help with this.
Sig Rho's Finest
Actually Tom, the thiefs remove the headlamps using crowbars, and damaging the fenders, bumper, and hood. They just jam them in, and pry the lamps out. I doubt this was what Siska had in mind.
I found a link to an old post about clearing the headlamps. The pics dont work, but the instructions themselves will be of help. Check it out http://www.acura-tl.com/forums/showt...threadid=40231
The basics are
Remove the front bumper:
1. First, remove the black plastic piece that covers the radiator support by removing the plugs using a flat head screwdriver while not forgetting the small plugs on either end of the grill.
2. Remove the screws inside each front wheel well towards the upper corner where the bumper meets the fender. Since the pics are down, you may want to crank the steering wheel in the opposite direction so that you can stick your head in there, and see it better.
3. Remove the plastic plugs & bolts on the underside of the bumper that connect it to the plastic undercarriage tray. They will be more visible when you get under the car.
4. Unplug the fogs
5. Pull the bumper forward to release it from the clips holding it on
Now the headlighst will be clearly visible, so
6. Disconnect all the plugs for the low beams, highs, turn signals, etc.
7. Remove the exposed bolts on the top (under the hood), and bottom of the headlamps.
That should be it.
The basics are
4. Unplug the fogs
That should be it.
6th Gear
Originally Posted by tpatel
what?! the a/c turned on? so the car lunged forward?! i dont get it
6th Gear
Thank you Mr. Hyde. I appreciate the information but I guess it's going to the shop since I'm not real comfortable with disassembling the front end of the car.
Everyone enjoy your long holiday weekend.
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
