Brake pad mod?
Old Aug 29, 2004 | 12:47 PM
TLSAnthracite's Avatar
Brake pad mod?
I found the endless brake pads but on the bottom there's this fine print that says slight modifications maybe needed for proper fitment. Does anyone know what slight modifications i need to do?
http://www.autocarparts.com/part/710/0
THanks
Old Aug 29, 2004 | 12:51 PM
TeknoKing's Avatar
never heard of those brakes....but loving my EBC.
Old Aug 29, 2004 | 03:50 PM
never heard of endless? those things are pretty good. i'm not saying EBC is not good, but endless is suppose to be better. But does anyone know what's the slight modification?
Old Aug 29, 2004 | 06:22 PM
patrick's Avatar
It's too bad my post on Endless Vita Nuova Type 1 pads won't show up anymore when you do a search. But you are in luck: here's my original post and review about these good pads:
http://www.acura-tl.com/forums/showthread.php?t=28822
I believe I fully covered everything regarding the "slight modification" that is required in the above post. If you have any additional questions, let me know.
Old Aug 29, 2004 | 06:26 PM
patrick's Avatar
Yup, Endless is better.
Old Aug 29, 2004 | 06:29 PM
patrick's Avatar
For more information about Endless brake pads (that are made in Japan), see the link below:
http://www.endlessusa.com
Old Aug 29, 2004 | 06:32 PM
TL260power's Avatar
have u consider getting metal master axxis brake pads? get them off ebaymotors.com for 84.00 for all four. Front and Rear.
Old Aug 29, 2004 | 06:36 PM
MADCAT's Avatar
I got the Satisifed Cermaic pads off TIRERACK. It is better than stock and runs cooler. Meaning less brake wear and better stopped distance.
Old Aug 30, 2004 | 01:21 AM
how much weaker are these and how's the brake dust?
Old Aug 30, 2004 | 01:22 AM
for the sanding down, is it osmething that u can sand down with sand paper or does it need something special to sand it down?
Old Aug 30, 2004 | 06:38 AM
shawn744's Avatar
Kollage is funn!
i'm goin EBC when i change mine....the brake dusk is a priority for me.....plus they're awesome in stopping power so it's all good.
Old Aug 30, 2004 | 03:13 PM
patrick's Avatar
LOL! No, you can't use sand paper, coz it's metal right...you need an actual machine sander that can sand down metal. Most mechanic shops will have this, just get them to do it for you (that's what I did). Once that hump is gone, you are good to go.
Old Sep 5, 2004 | 01:23 PM
david a. livingstone's Avatar
re pads ...I fitted ceramicool pads and they suck ....switched to Hawk HP plus ....and wow nice difference ...ps also using slotted and cross drilled rotors...
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
