HELP- Has Anyone used the 2002 TL fog switch with the Accord wiring harness???
Old 05-25-2001, 02:43 PM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Question HELP- Has Anyone used the 2002 TL fog switch with the Accord wiring harness???
I bought the Accord fog lights, that come with a wiring harness, but the TLs fog switch connection is too small. The Accord fog switch that came with the fogs has a larger opening where you plug the harness in.
Here's a picture of what I'm talking about.
On the right, the harness connection is too big to fit in the 2002 TL fog light switch.
Anyone have this problem???
Old 05-25-2001, 04:00 PM
snook789's Avatar
Post
Don't have this problem, but I got my car all apart right now trying to figure out how this "A" harness goes ...
It plugs right into the Inspire switch, but I can't follow the instructions by NighthawkBlack
Old 05-25-2001, 04:13 PM
Ain't No Other...
SinnedTL's Avatar
Post
are you sure its a little big??? because i know my inspire switch i got from Tim worked on my car, and supposedly the accord foglight switch is the same size with the same connections and i have personally seen the accord switch on the CL-S before, on my inspire switch, there was a real small tab that prevented my switch from fitting in the slot, but once i shaved off that lil piece, the piece fit right in...btw the switch goes in from the front of the dash into the back, not from the back to the front, if you know what im talking about...btw the new TL-S switch fits our 1999-2001 TL also...everything is the same...
Old 05-25-2001, 04:22 PM
NSXNEXT's Avatar
Post
No it's definitely the wrong size. The harness plug is way to big to fit the TLs switch. And it's a little different shape.
The problem might be that I have the fog light kit for a 2001 Accord, not just the wiring harness. Maybe the wiring harness you guys use is different.
Old 05-29-2001, 09:28 AM
NSXNEXT's Avatar
Post
Anybody????
Old 05-29-2001, 03:08 PM
BlingBling INSPIRE 32V
songoku's Avatar
Post
I didn't have any problem connecting switch to my fog kit. I've got 2001 accord kit too. but I used inspire switch though. I am not sure about TLS switch cause I haven't seen it. Maybe you should get inspire switch...
Old 05-29-2001, 05:00 PM
NSXNEXT's Avatar
Post
That's what I'm thinking.
Old 05-29-2001, 08:28 PM
songoku's Avatar
Post
Way to go NSXNEXT....
Old 05-29-2001, 10:04 PM
BlackTL2K's Avatar
Post
Anyone have a pic of the Accord fogs installed?
Old 05-29-2001, 10:49 PM
NSXNEXT's Avatar
Post
Check these posts for pics. Mine will be done tomorrow.
http://www.acura-tl.com/ubb/Forum1/HTML/008202.html
http://www.acura-tl.com/ubb/Forum6/HTML/000203.html
1999 Satin Silver Metallic 3.2 TL w/o Navigation
  • 18x8 Racing Hart C2s with 225/40ZR18 Dunlop SP Sport 9000
  • Comptech Springs, Sways, Exhaust, and Headers
  • NEUSPEED Front Upper Strut Tie-Bar
  • Red AEM CAI w/bypass valve
  • A'PEXi Digital VTEC AFC
  • Denso Iridium Plugs
  • Custom Mugen Grill
  • Inspire Tail Lights
  • Factory Underbody Kit and Spoiler
  • Clifford Intelliguard 9000 Alarm w/SmartWindows II
  • Alpine 6 disk CD Changer
  • BEL 945i Cordless Radar Detector
  • Burlwood Shift Knob & Trunk Tray
  • 20% tint
  • Rustoleum treatment
Fogs lights very soon
Old 05-30-2001, 01:19 PM
songoku's Avatar
Post
Hey NSXNEXT... you make my fog so proud..
welcome to Accord fog club (j/k)
Thanks NSXNEXT
Old 05-30-2001, 05:21 PM
NighthawkBlack's Avatar
Post
I have the answer to your problem if you are still looking for it. Post if you want to know.
Old 05-30-2001, 06:55 PM
Post
By the way which fog light kit did you get? The year and is it for the 4 door or coupe?
Old 05-30-2001, 10:12 PM
NSXNEXT's Avatar
Post
It's the 2001 Accord 4cyl sedan fog kit. I believe the problem is the Type S fog switch. It has a different sized connector.
If I'm wrong let me know.
  • 20% tint
Old 06-01-2001, 12:50 AM
Post
If the accord switch fits the harness, try to pry off the button top of the TLS switch and replace the accord switch with the TLS button front. It comes off easily by releasing the tab on the top and the bottom. Unless the outer case and the part you touch is made different than the Inspire and Accord switches, you should be able to switch the fronts. I had to do that when my Inspire switch burnt out and I needed to replace it. I just used the Accord switch with the Inspire face instead of the black face.
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
BoricuaTL
04-08-2016 01:08 PM
Ny1718
09-11-2015 09:21 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: HELP- Has Anyone used the 2002 TL fog switch with the Accord wiring harness???
