HELP! EBC Greenstuff and Rotora Slotted rotors.... squealing sometimes
Old May 4, 2006 | 09:50 AM
Bxscig's Avatar
I've installed the Rotora slotted and EBC green stuff for a while now, I would say 6 months at least and I noticed for a while now they they would squeal when I am braking lightly from 40mph to 30mph or 25mph. If I would to push a bit harder (with a slight jerk) then it would go away. I dont know what is going on. I tried the anti-squeal as well. I searched and saw a bunch of other people with the same setup with this issue.
I was able to deal with it in the winter since the windows are up but now since the windows are down, it annoys the shit out of me.
I bed them in and didnt brake hard during the first couple hundred miles... well maybe a couple of times since being in NYC it is hard not to sometimes.
Any suggestions?
Old May 4, 2006 | 09:52 AM
fsttyms1's Avatar
try bedding them in? I never had any noise from mine.
Old May 4, 2006 | 09:53 AM
Bxscig's Avatar
Bedding them in again? I thought you do that when they were new, how would I go over the same process now? It is just for those speeds under light braking.
Old May 4, 2006 | 11:08 AM
Bxscig's Avatar
Would this be the process to rebed them? http://www.zeckhausen.com/bedding_in_brakes.htm
Old May 4, 2006 | 02:16 PM
fsttyms1's Avatar
No your not supposed to do it when hey are new. Your supposed to be easy on them for atleastt 300+ miles. Then if you feel you need to then bed them in. Never right away
fsttyms1's Avatar
yea it will work.
Old May 4, 2006 | 03:02 PM
Bxscig's Avatar
Originally Posted by fsttyms1
yea it will work.
Thanks for the clarification
Old May 4, 2006 | 03:03 PM
NSXNEXT's Avatar
Did you put the anti-squeal on the backs of the pads?
Old May 4, 2006 | 03:15 PM
fla-tls's Avatar
On the way!
I think the green stuff pads come with a black anti-sqeal "sticker" that goes onto the pad backplate. Did you remember to put this on the pads before installing them?
Old May 4, 2006 | 04:31 PM
Bxscig's Avatar
Yup, I used the anti-squeal Thought I didnt put enough the first time and I cleaned it off and put more this time with no avail.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
