help! cooling fan sensor problem
Old Jul 23, 2007 | 10:47 PM
s270r's Avatar
Unhappy help! cooling fan sensor problem
hey guys,
I have a problem with my cooling fan on my 02 TL-S
After I turn off the car, it still runs for another 10-15 minutes even when it is not hot... I talked to a mehanic he said it might be a cooling sensor, where is it located? or do you know what the problem might be?
please help
Old Jul 24, 2007 | 01:09 AM
01tl4tl's Avatar
lower right corner of radiator
Old Jul 24, 2007 | 01:23 AM
03 TL TypeS's Avatar
*03 TL Type S*
i had that promblem too i'm not sure where it is but ur gonna have to get that sensor fixed. otherwise ur fan will keep doing that
Old Jul 24, 2007 | 07:55 PM
s270r's Avatar
thanks guys, can anyone show me a picture of that?
Old Jul 24, 2007 | 07:57 PM
Deity711's Avatar
Yes it is!
I had the same problem when I had my TL, except mine would stay on and drain my battery till it was dead.
And it was always one of these deals where it'd never do it in front of the service rep, so they'd tell me crap like "check your battery connection."
Old Jul 24, 2007 | 07:58 PM
s270r's Avatar
also, can oneone tell me what part number is?
thanks
Old Jul 24, 2007 | 08:05 PM
fsttyms1's Avatar
37773-PGE-A01 SWITCH, THERMO
(#14)
http://www.acuraautomotiveparts.org/...catdisplay.jsp
38 bucks
Old Jul 24, 2007 | 08:07 PM
t0ast's Avatar
2Poor 2Furious
mine did that, too. I checked the radiator, and it wasn't full so I topped it off. Try that?
Old Jul 24, 2007 | 08:09 PM
fsttyms1's Avatar
there is also a sensor on the thermostat housing that tells the system to operate. Id start with the radiator sensor (i dont have my manual near by to tell you how to test teh sensors)
Old Jul 24, 2007 | 08:22 PM
s270r's Avatar
thanks for all of the input. I ll try all that tomorrow
Old Jul 24, 2007 | 08:26 PM
01tl4tl's Avatar
toast
if you had a low bottle and low radiator you have a LEAK
Low radiator only- full overflow bottle-possible cap problem
most likely:
another member was doing that fill and drive- and after popping the motor, learned a rock had hit the radiator
That coolant went somewhere- it should NEVER just disappear
and the temp guage should stay steady 1 mark below half- ac-hills-whatever
anything else indicates a problem
Old Jul 25, 2007 | 01:24 PM
s270r's Avatar
I checked the level of the antifreeze today... and it was empty I filled it up and everything works normal now.
Thank you all!
Old Jul 25, 2007 | 02:47 PM
01tl4tl's Avatar
That means you havd a cooling system leak
Have it tested and repaired IMMEDIATLY
A low bottle is a warning sign of empty radiator
Old Jul 25, 2007 | 05:05 PM
s270r's Avatar
I just checked it again... half of a container is gone again, but there is nothing under the car... where could it be leaking?
the front bumper was hit, and the reinforcer was pushed in, so the repair shop pulled it back out but they didn't say anything about the radiator.
Does it have to have a hole in the radiator in order for it to leak? or can it be just one time thing? The temperature gauge shows a normal temperature.
I tried filling up the container with antifreeze again; I want to see if it will disappear again.
Old Jul 25, 2007 | 05:15 PM
fsttyms1's Avatar
how low is the radiator?
Old Jul 25, 2007 | 05:57 PM
s270r's Avatar
Radiator was full, but the reservoir was half full when I filled it up the second time. I did not check the radiator the first time I filled the reservoir.
Old Jul 25, 2007 | 06:00 PM
fsttyms1's Avatar
well i would watch the level for the next few days. if it continues to drop you will need to find the problem
Old Jul 25, 2007 | 06:01 PM
s270r's Avatar
yeah.. thanks! I am just glad that the fan is back to normal... at least i know that its not the sensor.
Old Jul 25, 2007 | 06:24 PM
01tl4tl's Avatar
It means there is a serious coolant leak- front end damage often results in pinhole leak in radiator
The bottle has a hot and cold full and minimum marks- follow them- filling the bottle completely is bad- radiator filled first when cold- then the bottle to correct full mark
Do not think this happened once and is gone!!
They other thing to check is the engine oil dipstick- is it above full and grey and foamy looking or oil slick on water looking?
Old Jul 26, 2007 | 09:58 AM
s270r's Avatar
Ok, I checked the level of coolant this morning and found out that the radiator is full, but the reservoir is only half full. I checked under the car, and there was a little bit of moisture, so I am assuming the radiator does leak... sigh... What should I do?
Originally Posted by 01tl4tl
It means there is serious coolant leak- front end damage often results in pinhole leak in radiator
After the car was hit, I drove it for about 6 months before fixing it... and there was no problem, the problem started when i got it back from the body shop -fixed. I thought maybe the shop spilled it or something, but I can't prove anything right now.
I checked the engine oil dip stick and it looks good, even though it's time for an oil change.
Old Jul 26, 2007 | 10:24 AM
01tl4tl's Avatar
good- no water and oil mixed in the engine oil-
Now look in the phone book for radiator repair and ask how much for one for your car
They do installs and repair yours if able, or get good prices on replacements
Also check zone and similar for aftermarket radiator-
easier to replace than try to fix a wrecked one
Old Jul 26, 2007 | 10:25 AM
01tl4tl's Avatar
The sysytem is under aprox 15 psi pressure when engine running normal
When you shut off- very little may drip- start it and drive- watch out below!!
Old Jul 26, 2007 | 11:21 AM
s270r's Avatar
what if I wont fix it? I have been driving like this for about a month and nothing happened... the only thing is that the fan works for about 10-15 minutes after i turn off the car.
Old Jul 26, 2007 | 12:40 PM
01tl4tl's Avatar
Do you have any idea how hot the engine must really be to make that happen!!
The service writer in me wrings hands together evily and says:
besides putting strain on the battery and potential overheating with dire consequences, nothing to worry about- drive it till it drops- and it will
oh- and the coolant mix not being 50/50- that would be bad because the PH changes and corrosion takes over and kills....dont worry about that- your going to need a head gasket, at the least, when you overheat this thing
the guage does not tell all- if it ever says more than 1 mark below middle- there is something needing attention- unless you like calling AAA and spending way more to repair the result of the original problem plus the original problem
The decent helpful person in me says:
If you take it to a radiator shop they will put a special test cap on that pumps up the system to operating pressure with engine off.
Where the coolant squirts out is the leak- have that repaired if possible or replaced
-a check of kragen has them for 180- as a referance point
cycdaniel
Dec 17, 2019 10:58 AM
TL-Rocket
Dec 4, 2017 06:59 AM
01CLOwner
Oct 9, 2015 01:07 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
NSolace
Sep 3, 2015 08:02 PM
