HELP!! change out. how do you remove belts?
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
hi guys. pulley install. i cant seem to figure out the belt adjustment. does anyone know how to loosen the belts. 2003tls thanks
SH-AWD
For the alt./compressor belt use a 14mm wrench to pull the tensioner back off the belt and you can remove it (I find that it's easier if you release the P/S fluid reservoir and move it to the side). For the P/S belt you'll need to loosen the 12mm adjusting nut toward the top of the pump, there's a 12mm lock nut under the pump you'll have to loosen and then a 12mm bolt toward the rear of the pump that needs to be loosened to let the pump pivot.
Show me da MONEY
Wow Dale,
I am impressed how did the pulley installation part of it go? A DIY would be great for when I can finally do mine. (when I get past payment of my speeding ticket, hehehehe)
cycdaniel
12-17-2019 10:58 AM
