Help av6 transmission
Old Jul 13, 2021 | 10:43 PM
griffrider's Avatar
3rd Gear
Is this the correct trans for my 01 acura tl av6 swap
Old Jul 19, 2021 | 05:18 PM
whitetiger5's Avatar
I wouldn't go for that. They fail to provide a part or transmission number and the pictures they include show the spin-on filter/oil jet kit indicative that this is just a retrofitted Acura TL transmission; not an Accord V6 (AV6) BAYA transmission.
I took a look at the site you have listed there; if the pics are accurate; it has the oem transmission cooler lines which lead me believe it's a transmission from an Odyssey; which has the same rate of failure as the Acura TL.
Old Jul 23, 2021 | 11:01 AM
griffrider's Avatar
3rd Gear
I got it
I got it and installed It. Everything looked good besides the the torque converter not lining up. But changed everything including the plate
Old Jul 23, 2021 | 11:11 AM
So the JDM trans above is working, with no problems?
Please specify which torque converter and plate you used.
Old Aug 22, 2021 | 07:59 AM
ImBroke's Avatar
So you were told not to get it and got it anyway. You had to reuse your TL torque convertor, which is advised against in the FAQ. I too like to live dangerously.
jansenjosh
Apr 28, 2017 12:53 PM
ssp81777
Jan 19, 2014 05:41 PM
02TLblu
Apr 6, 2010 08:23 PM
rickjstafford48230
1G CL Problems & Fixes
Mar 19, 2008 11:23 PM
