Helms Manual Help Needed
Old Nov 22, 2006 | 05:17 PM
sbuswell's Avatar
I need 2 more gears
Can someone post the pages of a helms manual showing the replacement of the front motor mount in our cars please? even if it's for 00-03 I am sure it will be the same. I will be changing mine on friday.
thanks.
Old Nov 22, 2006 | 05:53 PM
fsttyms1's Avatar
ITs really not in there. (good pics) Basically you remove the top bolt on the motor mount bracket. Place a jack under the motor, remove the 3 bolts that hold the bracket to the motor, remove teh 4 bolts for the mount. Disconnect the vacuum tube to the mount and remove the mount. Reverse order for installation
Old Nov 23, 2006 | 08:07 PM
sbuswell's Avatar
I need 2 more gears
I am going to be replacing the mount tomorrow and I just want to make sure I have everything figured out correctly so it goes smooth and doesn't take me forever.
1. remove top bolt on mount'
2. jack up engine using block of wood between jack and oil pan
3. remove the 4 bolts on the base of the mount, remove vacuum hose from bottom of mount
4. slide out old broken mount
5. slide new mount in
6. tighten all 4 bolts on base of the mount
7. lower jack
8. tighten top bolt on the top of the mount
Let me know if I am missing anything or if there is anything I should watch out for while doing this, common problems, hassles, etc. This is the first time I will have changed an engine mount in my life and I am confident I can do this no problem at all, but want to be sure I do it right.
Thanks.
Old Nov 24, 2006 | 09:37 AM
pmptx's Avatar
Honda+Blue=My garage
That pretty much hits it on the head. I replaced front and side and that is exactly how it worked. Loosen, lift, remove, replace, drop, tighten.
Old Nov 24, 2006 | 04:57 PM
fsttyms1's Avatar
I would remove teh mout bracket from the motor. It will make it easier to get out
Old Nov 24, 2006 | 08:38 PM
sbuswell's Avatar
I need 2 more gears
i changed it today and I did have to remove the mount bracket to get it out. it wasn't that hard and now my car does run smoother and my SOTP meter is reading much better response and overall acceleration is noticeably improved.
Old Nov 24, 2006 | 11:07 PM
fsttyms1's Avatar
Old Dec 6, 2006 | 08:10 PM
sbuswell's Avatar
I need 2 more gears
one more question, when I chnaged the mount I didn't fill the new mount with hydraulic fluid, was I supposed to?
Old Dec 6, 2006 | 09:19 PM
fsttyms1's Avatar
No, its already in it and sealed. If it leaks it out then the mount is bad
Old Dec 6, 2006 | 09:38 PM
sbuswell's Avatar
I need 2 more gears
cool, no leaks, when I took the old mount off fluid was spilling out of it, is that why the old mount was bad?
Old Dec 6, 2006 | 09:43 PM
fsttyms1's Avatar
yes, if it leaks out its bad
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
tonio
Feb 5, 2019 05:43 PM
jamestheunderdog
Jul 19, 2016 07:58 PM
asahrts
Sep 4, 2015 05:55 PM
holografique
Sep 1, 2015 07:54 PM
