Hello First post and could use some advice
Old Oct 7, 2014 | 11:26 AM
KtownKid's Avatar
3rd Gear
Hello,
I have an 01 Acura TL. I started my car this morning and when I hit the accelerator, I heard a strange noise. It only seems to do it when applying the Gas pedal. It sounds like something is being restricted or a dull knocking kind of sound. I made 2 quick You tube videos.
COuld anyone tell me what they think it may possibly be?
Car has 118,000 miles on it. I had Timing belt, pulleys, Tensioners and water pump replaced 5,000 miles ago.
https://www.youtube.com/watch?v=L7ZD...ature=youtu.be
Cheers folks!
Old Oct 7, 2014 | 11:29 AM
KtownKid's Avatar
3rd Gear
Old Oct 7, 2014 | 04:11 PM
01tl4tl's Avatar
I don't have speakers but the ac belt tensioner is a popular item to wear out
Especially when the tension is released for other work and then re-applied
take a listen with a mechanics stethoscope ($4-10) or touch the tip of a long screwdriver to non moving part of tensioner- listen to top of screwdriver,
but the stethoscope can be obtained at harbor freight tools or any parts store and everyone should own at least 1, I have 3! get them on sale and can always find one close by wherever in the garage I am , toolbox, wall tools, race box, misc loose tools
Old Oct 7, 2014 | 04:13 PM
01tl4tl's Avatar
try revving to 2500 and let off. with and without ac- does it get worse with ac ON? that's your prob! that belt tensioner
get the entire unit- roller-arm and tensioner assembly, under 100 bucks
plenty of other threads and a diy on installation on here
mine started making noise at 45,000 miles and finally went bad at 80kmiles
Old Oct 7, 2014 | 10:39 PM
Skirmich's Avatar
Sounds like a faulty Tensioner Bearing.
Old Oct 9, 2014 | 08:15 AM
KtownKid's Avatar
3rd Gear
Thanks for the responses. It turned out the Bearing on the Idler Pulley tensioner was bad already. Looks like im back on the road again.
Old Oct 9, 2014 | 01:19 PM
Skirmich's Avatar
Knew it.. Glad you solve it out.
Soul_Deamon
Nov 13, 2018 04:44 PM
urbtsx
Mar 4, 2017 06:53 PM
BobbyGraham388
Oct 22, 2015 05:05 PM
lilian_rz
Integra
Oct 18, 2015 01:17 AM
BlueAquarian
Sep 10, 2015 02:18 PM
