Headunit removal???
Old Jun 19, 2006 | 11:54 PM
Rhlieu's Avatar
Headunit removal???
Hey guys wassup!
I am trying to take out my headunit so i can put in a 02-03 unit in so i won't ever have to get annoyed by the unit not playing burn cd's. However, i am having problem taking it out. I have taken the wood trim on both side on the center out, i took about 6 screws out too. I got these two annoyass white tabs, i took out one with a lot of force, i am having a problem taking the one on the driverside out, has anyone taken their deck out? Fsttyms1 linked me a DIY, however the link is dead, any help would be GREAT!!!!
Old Jun 20, 2006 | 05:28 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
it's probably easier better explained by people other than me if you look it up in the audio forum, but those white tabs don't need to be removed (if i recall). on the 02-03 TL you have to remove screws from the side as well, so you will need to remove the trim panel along the sides of the console. there are screws behind the driver knee panel and the glove box i believe (haven't done it in a while). good luck.
SSTS
Old Jun 20, 2006 | 07:48 AM
JMAL's Avatar
i just did it this weekend. you have to take the knee panels off to access 3 screws on each side of the radio. there is a diy in the audio/video section that i used, it was perfect. use the one in the acura CL sections. it the same steps.
good luck, pm me if you have questions.
Old Jun 20, 2006 | 07:11 PM
bmoreTLS's Avatar
sumbdy gettin used 2nite!
follow the diy for this:
www.ngumedia.com/Acura
you should be able to figure it out using the Denison icelink install guide. It shows how to take it out.
It should only take you about 20 mins, 30 tops to get it out. Just make sure you remember how the screws go back in.
Old Jun 20, 2006 | 07:12 PM
bmoreTLS's Avatar
also, you might wanna check out abunchofcars.com for another good diy
Old Jun 21, 2006 | 03:38 AM
Rhlieu's Avatar
SWEET!!!! Thanks for all the links and info, i love this fourm, everyone is so helpful!
Found out the hard way about the knee panel and the screws behind it, and YES those white tab has nothing to do with taking the unit out.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
