Headlight Bulb upgrade
Old Sep 11, 2021 | 03:01 PM
Abarmard's Avatar
4th Gear
Question Headlight Bulb upgrade
Good afternoon Folks,
I'm a new comer to this forum.
Just bought a 2003 Acura TL (Base model). I Want to upgrade the headlight Bulbs, both, high and low beam. I could not find any LED Bulbs for Low beam but there are plenty for high beam. I found these bulbs for low beam but they are not LED;
Amazon Amazon
Any body knows a good LED bulb for low beam?
The other question I have is as how to replace them? It that difficult? I'm good with tools and do home mechanic things, etc. Is there any stepwise approach that you could share with me?
Thank you very kindly in advance
A.
Old Sep 12, 2021 | 09:44 PM
DP01TL's Avatar
I do believe the low beams should be HID, and if so, you probably only need new bulbs to have them nice and bright again.
On our 2001 I wasn't satisfied with new bulbs and repolished stock housings, so I bought new housings. Now I need to swap everything out.
Old Sep 13, 2021 | 07:02 AM
$30 HID's..., I mean you get what you pay for!!!
dont be surprised if the $30 HID's crap out on ya!!
Aftermarket LED's are not anywhere near close to being a competitor to a very nice OEM HID bulb, like Phillips.
it's def. your car and you can do whatever you would like to do to it, but with your proposed plans, it would be a serious downgrade to throw LEDs into the low beams. the $30 HID bulbs also would not cut it.
but if you would like to try, go right ahead!
Old Sep 13, 2021 | 12:21 PM
DP01TL's Avatar
I wasn't happy with the low beam headlights when I got the car, as they were both dimmer and one had an off color. I bought the OEM bulbs and it was a world of difference.
The high-beams are a serious disappointment being standard halogen bulbs, but I did end up buying new LED high beam bulbs, but have yet to put them in. I am hoping they at least compete with the HIDs in regards to color and output. If they do I will post which LEDs I purchased as they are the newer type that doesn't need an active fan to cool them. I figured it was a good choice seeing how little you run the high beams, and even if you do run them for a longer time it is somewhat infrequent or in cooler outdoor temps.
Old Sep 13, 2021 | 12:23 PM
https://www.theretrofitsource.com/d2...D2R?quantity=1 Get these replacements
Old Sep 16, 2021 | 03:30 PM
Phuong Pham's Avatar
Get Philips D2R HID bulbs in 4300 K.
Old Sep 22, 2021 | 07:59 AM
Abarmard's Avatar
4th Gear
Question Remove the Front Bumper?!
Good morning Folk,
Thank you for those replies.
My question is;
If I need to remove the front bumper in order to access the Headlight bulbs (Low and high Beam)? Or is there an easier way to do it?
Thank you
Old Sep 22, 2021 | 02:51 PM
TheMightyQuinn's Avatar
Registered Nonmember
No, you do not need to remove the bumper to change high or low beam bulbs. You will need a security torx bit to remove the covers for the low beams. You may need to remove the coolant reservoir and possibly windshield washer fill tube for more room to get the bulbs out.
Just pop open your hood and look. Its right there.
Old Sep 22, 2021 | 03:01 PM
Abarmard's Avatar
4th Gear
Thank you
xrochester
Jul 19, 2025 07:06 PM
hondeducation
Dec 22, 2017 02:37 AM
MrTee12
Sep 29, 2017 10:06 AM
CamPhil
Mar 22, 2015 06:54 PM
devasta
May 5, 2005 03:47 PM
