Headlight alignment
Old Sep 12, 2008 | 10:31 AM
mynameishello's Avatar
Headlight alignment
Ok.. so i just installed my new bulbs in yesterday. When i went to align them up against a wall, i noticed there isn't like..i dont know how to say it..but like there isn't a clear "cut off" where the light is. Or there wasn't a cut off in the first place? I kept playing around with aligning them but it seems there is no cut off. I'll post up a pic later to let you guys see what i mean.
Old Sep 12, 2008 | 10:45 AM
Does it have anything to do with the reflector or anything like that? Also, is there a certain way the bulb is supposed to be positioned? Any help would be greatly appreciated!
Old Sep 12, 2008 | 10:53 AM
01tl4tl's Avatar
the new bulbs MUST go in the exact same way the old ones came out
You can tell by the external electrode- use that as a referance
DO NOT twist the bulb to change position- it will damage that electrode!
Remove bulb- rototae in hand- reinsert in correct position
Place metal arm clip in place and locked-
Done
Old Sep 12, 2008 | 10:56 AM
would that fix the "cut off" part also? When i went to face the wall, the lights were just like a big blur. Wasn't sharp or clear at all...
Old Sep 12, 2008 | 11:06 AM
phee's Avatar
I got the Shifts
dont touch the bulb with your bare hand please
Old Sep 12, 2008 | 11:10 AM
I didn't, i wore a rubber glove. Not sure if that's a good idea or a bad one but i dont want to burn my hand...but would touching the bulb with my bare hand make the light output worse?
Old Sep 12, 2008 | 02:07 PM
totaledTL's Avatar
Oils from your fingers contaminate the glass which may lead to early failure. If you already touched them gently wipe clean w/ alcohol.
hashbrown
Feb 18, 2022 11:20 AM
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
