Headlight adjusters don't move
After installing my 5k HID's the other day everything seemed to be normal. I didn't adjust it because I didn't have the proper tools to do so. Next day comes along and my buddy and I decide to adjust it, and for some reason we ended up taking off both headlights because after adjusting the lowbeams, the highbeams were completely out of wack. After correctly reinstalling the headlights, both the adjusters for each side stopped working. We did not drop the headlights or force anything in or out. ALL nuts and bolts are in the correct spots. We looked at the adjusting 10mm bolt itself and it does show signs that it is moving, BUT when we turned on the headlights the beams were not moving at all even after multiple revolutions. We turned the bolt BOTH ways and still no results.
At this point, I am stuck, even after searching through all the threads, no results. Please help AZINE.
the bolt? why are you using it instead of the normal method??
Look at top of housing- see the arrows and up/down?
ok now see the raised V shaped groove on the rear of housing above the adjuster nut?
insert a + screwdriver into the groove - tilt tool as needed, slide down the groove until the tip of the + fits into the teeth of the top gear--thats the real adjuster!
now twist screwdriver left or right as directed by the arrows to raise or lower beam.
see: headlight adjust diy for exact setting height and ~practical measurements~
you may have tightened the nut that holds everything together--
so now its bound and wont turn? (guessing)
thats what I was trying to explain - how to use the screwdriver method
if they wont turn anymore- its reached a limit stop
remove housings and inspect
are the bulbs in correctly?
Same thing happened with my Right Headlight I think its broken cuz my Left light Will keep aiming up if I wanted to, I needed to lower it so it will aimed with the Right Side..
Design Flaw? Perhaps.
rockyboy
08-04-2024 10:35 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
