Headers resonances
Old Jun 20, 2003 | 06:01 PM
asiankidd's Avatar
Headers resonances
ok i talked with comptech yesterday, and they said that the resonance / vibration comes from the flex bellows, they said the original run that the flex joint was to stiff causing the whole exhaust to vibrate at 2000-3000 rpm under engine load, the fix was the get the flex bellow replaced, my question is they want 200 bucks to fix that lil part, im for one not willing as i have heard you can loosen the weaves? i have done countless searches, but does anyone heard about this and have tried it? thanks, also this method should work for obx owners too...
JON
Old Jun 22, 2003 | 11:01 PM
PeterUbers's Avatar
My comptechs have NO resonance, do yours?
Old Jun 22, 2003 | 11:53 PM
asiankidd's Avatar
some of the earlier ct headers have the resonance problem.....thats why i brought it up
Old Jun 23, 2003 | 10:32 AM
bug230's Avatar
mushroom mushroom
my OBX used to have a resonance prob. but I went back to retighten the header bolts one of them was very loose. once that was done I had no more sesonance ( or very little at least).
Old Jun 23, 2003 | 02:12 PM
bigman's Avatar
'Big Daddy Diggler'
my obx's resonated a little when i first got them and it went away after a while.
Old Jun 24, 2003 | 02:45 PM
NighthawkBlack's Avatar
My Comptechs have serious resonance issues right after I put the header on and I have been talking to them for over a month. I still am waiting for a solution.
Old Jun 24, 2003 | 04:13 PM
asiankidd's Avatar
any updates on wat they have told you and wat you have researched?
Old Jun 25, 2003 | 12:31 AM
I should know this weekend what the exact cause is.
Old Jun 25, 2003 | 01:49 AM
asiankidd's Avatar
alrgith thanks
Old Jun 25, 2003 | 01:50 AM
asiankidd's Avatar
btw can you describe the sounds of yoru resonance? thanks
Old Jun 25, 2003 | 07:04 AM
Well AT idle with foot on brake and in Drive with AC on its like a rattle that is being muffled so not quite metal on metal but definate vibration. THen in reverse or neutral, no sound which leads me to believe since the RPMS dont change, that something is touching when the engine shifts slightly for the drive position.
Old Jun 27, 2003 | 03:49 AM
asiankidd's Avatar
find out anything new yet?
Old Dec 3, 2003 | 10:02 AM
tl-steve222's Avatar
Re: Headers resonances
JON
Flex Bellows?
Old Dec 3, 2003 | 11:18 AM
The end result with my situation was that after replacing the downpipe without even moving the manifolds, the problem went away instantly. No crazy vibration. So I guess even a part that really only has one flex area could be bent wrong or so rigid or not rigid enough that it could produce a vibration sound. As to what exactly is wrong with the downpipe I removed is for comptech to test and frankly should not be the concearn of the customer. I just chalked it up to a defective part.
Old Dec 3, 2003 | 01:50 PM
goldendragon576's Avatar
TL-S driver
I keep meaning to ask Park Ave Acura if they have any cure for this but I keep forgetting. I think I got used to this problem already because I only hear it when I'm paying attenion to it, otherwise I don't hear it that often.
Old Dec 3, 2003 | 02:10 PM
NSXNEXT's Avatar
If you can take the downpipe off you can, in some situations, bend the flex pipe to loosen up the weave. I had the same problems with my Comptechs. I was one of the first to get them. Comptech shipped me a new downpipe and they took care of everything.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
merc009
Sep 29, 2015 03:06 PM
Rcelestino93
Sep 23, 2015 10:01 PM
