Header Exhaust Leak....
Old Apr 23, 2003 | 05:11 PM
kegrun's Avatar
Post Header Exhaust Leak....
I am installing my headers tomorrow evening and was wondering what happens if there is an exhaust leak?
Old Apr 23, 2003 | 06:04 PM
fla-tls's Avatar
On the way!
You'll hear what amounts to an odd ticking noise at idle. One of the weekend car shows on TNN had a very good suggestion regarding header installation.
Once the headers are installed, allow them to heat up and cool down several times (drive it for a few days). Then, go back and re-torque the bolts. This allows the gaskets to get compressed during the heat-up cycle a few times so that they shrink to their broken-in thickness.
That way they'll stay good and tight!
Old Apr 24, 2003 | 09:05 AM
paxus's Avatar
Really? That sounds like it's theoretically a good idea. Anyone actually do this here on the boards?
Old Apr 24, 2003 | 11:47 AM
Ray_Khan's Avatar
yes, this advice is correct....this is what I did when installing my turbo and manifold on my Audi. Infact...I should meet up with Ferizzo soon and retorque his.
Old Apr 24, 2003 | 03:30 PM
Edward'TLS's Avatar
6G TLX-S
If there is any leak in the exhaust plumbings, you will see black carbon desposits all over the cracks after some time. So black soots on the outside of the pipings indicate wherever there is an exhaust leak.
Old Apr 24, 2003 | 09:26 PM
RES
Good idea! I just retightened my bolts 2 days ago after having my OBX's on for about a month and every bolt was slightly loose.
When there is a leak the car sounds different, in my case it was anoying. Good luck!
Old Apr 25, 2003 | 12:47 PM
bug230's Avatar
mushroom mushroom
Thats what I did..its the only way to go.
Old Apr 27, 2003 | 10:08 PM
yield2s's Avatar
whats the torque specs on exhaust man???????
Old Apr 28, 2003 | 12:00 AM
PeterUbers's Avatar
RES -- how do you like the OBX headers? Is there really an annoying resonance at 2500-2800 rpms??
How's the power upgrade?
Old Apr 28, 2003 | 02:14 PM
bug230's Avatar
mushroom mushroom
I have a question...If one of our cars had an exhaust leak would there be a loss of HP? and if so would the amount of HP loss be noticable?
Old Apr 28, 2003 | 02:33 PM
There isn't much resonance at 2500rpm, but you can hear it. If you have radio on you can't. HMMM save $700, can turn it up louder. LOL.
Old Apr 28, 2003 | 04:54 PM
fla-tls's Avatar
On the way!
Comptech doesn't give them for the CL/TL/Accord, but they do give them for several other models.
NSX - 25 ft-lbs
CRV - 23 ft-lbs
Civis Si - 23 ft-lbs
Integra - 23 ft-lbs
and the odd ball
RSX - 33 ft-lbs
I'd say you're safe with 23-25 ft-lbs (i.e. NSX)
(That's for the header->cylinder head bolts.)
Old Apr 28, 2003 | 11:07 PM
PeterUbers's Avatar
What does resonance SOUND LIKE??
And can I hear it from the outside as well if i'm cruising w/ my windows down?
What if I'm cruising on the highway at 2750 rpms... is the resonance constant?
Old Apr 29, 2003 | 09:07 AM
fla-tls's Avatar
On the way!
It sounds a little like the sound you get when blowing over a bottle top. Can you hear it from the outside with windows down? Probably.
If you're on the highway will you get constant resonance? No. It usually happens when the car is cold - and only for a fraction of a second. It's no big deal.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
joflewbyu2
Oct 8, 2015 11:16 AM
prbori
Sep 27, 2015 01:37 AM
