Hardwire V1
Old Apr 1, 2007 | 04:18 PM
see_fu's Avatar
Illusion Lighting
Hardwire V1
Does anyone have step by step instructions on how to hardwire V1 for a 03 TL? I am a noob. Thx.
Old Apr 1, 2007 | 05:18 PM
02TLSfan's Avatar
Prick of the month
Check the DIY section
Old Apr 1, 2007 | 07:56 PM
Ramojr's Avatar
Put the shoes back on in
https://acurazine.com/forums/showthr...ighlight=radar
I followed this with mine.. But, when you get to the fuse panel, use the fuse #12.. It's the wiper fuse and should be a 30 amp fuse, on the driver side.. Using that fuse will only have the V1 come on when the key is in the 2 position or when the car is running.. The ground is a screw/bolt that is pretty easy to tell.. It already has a wire grounded to it.. It worked out great for me..
Old Apr 1, 2007 | 09:01 PM
fsttyms1's Avatar
Also the back side of the drivers side fuse box has spots to attach. 2 are constant, 2 are switched and one is with the lights on. All you need is a spade connector to connect to it.
Old Apr 1, 2007 | 10:19 PM
see_fu's Avatar
Illusion Lighting
Hey thx guys. It took me about 30 minutes to hardwire the V1. Thx again.
deyainrdy4ds
Sep 22, 2015 10:15 AM
Elegant TYPE S
Jul 21, 2005 11:08 AM
glott
May 17, 2005 07:40 PM
SocaliCLS
Oct 24, 2004 05:24 PM
