Hard to start??
Old 07-25-2002, 03:18 AM
4th Gear
Angry Hard to start??
Did someone know my TL-S is hard to start,
always in morning,what's wrong!:wow:
Old 07-25-2002, 07:38 AM
NsX Pilot's Avatar
can u give us some more details like do u need to crank it alot b4 it kicks over ? ...what kind of gas are you using ?........are u just turing the key or do u give it gas too when ur starting ??
Old 07-25-2002, 09:54 AM
joneschop's Avatar
03 TLS I have had to crank mine a few longer seconds before it has started. Seems like only on a very hot day in the sun all day
Old 07-25-2002, 02:16 PM
still a Masshole
ferizzo's Avatar
I have the same issue and someone told me it had to do with the High Compression of our engines. Mine needs to crank a few times before starting and sometimes it hestitates. Only once did it not start though...waited 5 seconds, tried again and I was good to go.
Old 07-25-2002, 06:41 PM
bdimc2001's Avatar
I've always had alittle hesitation with my TL...it's very very common and it's not even a problem...I've got 33K miles now..and it does that on every start...only once has it not started...but like Ferizzo said..i just tried it again after a few seconds then it started right up.
Old 07-26-2002, 03:57 AM
4th Gear
[QUOTE]Originally posted by NsX Pilot
can u give us some more details like do u need to crank it alot b4 it kicks over ? ...what kind of gas are you using ?........are u just turing the key or do u give it gas too when ur starting ?? [
/QUOTE]
When i turn the key for a few sec. The engine still can't start
I'm using Chevron Supreme Plus 94
snorf
11-04-2019 06:44 AM
obert
12-14-2015 11:36 PM
redsox68
09-16-2015 06:18 PM
PortlandRL
09-14-2015 12:01 PM
Username 0
2G TSX Problems & Fixes
09-11-2015 09:50 PM
Quick Reply: Hard to start??
