Hard to start??
Did someone know my TL-S is hard to start,
always in morning,what's wrong!:wow: |
can u give us some more details like do u need to crank it alot b4 it kicks over ? ...what kind of gas are you using ?........are u just turing the key or do u give it gas too when ur starting ??
03 TLS I have had to crank mine a few longer seconds before it has started. Seems like only on a very hot day in the sun all day
I have the same issue and someone told me it had to do with the High Compression of our engines. Mine needs to crank a few times before starting and sometimes it hestitates. Only once did it not start though...waited 5 seconds, tried again and I was good to go.
I've always had alittle hesitation with my TL...it's very very common and it's not even a problem...I've got 33K miles now..and it does that on every start...only once has it not started...but like Ferizzo said..i just tried it again after a few seconds then it started right up.
[QUOTE]Originally posted by NsX Pilot
can u give us some more details like do u need to crank it alot b4 it kicks over ? ...what kind of gas are you using ?........are u just turing the key or do u give it gas too when ur starting ?? [ /QUOTE] When i turn the key for a few sec. The engine still can't start I'm using Chevron Supreme Plus 94 |
