Is this happening to anyone else?
Old Jul 19, 2009 | 02:44 PM
miamirice's Avatar
Yup
I searched for this issue but I'm not even sure what to call it, so I'm not getting good results. (There are 495 threads with "door" in the title.) I know I can't be the only one it's happening to. Both of my rear doors have this problem :
The bottom edge of it is actually completely unglued, too, I just mushed it into place so it wouldn't flop around.
Old Jul 19, 2009 | 03:00 PM
sleepersho's Avatar
it happened to mine too,that seal doesnt have much surface area contact with thr back of the chrome trim,so it's easy for it to come unglued. you can try using clear silicon to put it back in. It'd be easier to do with that chrome corner trim off,it's just a push clip that holds it in.If you try pulling it off,I'd be REALLY careful,the clips almost always break and it's easy to to bend the trim piece.
Old Jul 19, 2009 | 03:01 PM
Razzi's Avatar
T-Swzy
mine's doing the same thing. so far all i've done is jammed it back in and pray
Old Jul 19, 2009 | 03:20 PM
vdiddy210's Avatar
Sitting Fressshhh
yep! it's happened to my car
back driver side..
if you don't know what to do to put it back in place, get some super-77 (3M made) it's spray glue, it should fix it because it's workable...spray some on (make sure you cover surfaces) and jam it back in. wipe any excess and let it set
Old Jul 19, 2009 | 03:53 PM
miamirice's Avatar
Yup
Hm...
It seems like mine is beyond repairing in this way. Looks like parts have ripped or torn.
back driver side..
What it is supposed to be glued to? Before it was held in place by clips, but the holes in the rubber piece have been torn, I think. I hesitate to glue it to the pillar behind it because, well, gluing rubber to painted metal doesn't seem right.
Has anyone switched them out? I'd consider replacing if it the parts weren't too expensive and I could do it myself.
Old Jul 19, 2009 | 04:23 PM
Hot Boi's Avatar
Grippin' Grain
Mine has been that way for yrs now. I never bothered to fix it though.
Old Jul 19, 2009 | 04:59 PM
vdiddy210's Avatar
Sitting Fressshhh
haha it's glued to the inside. true it was clipped before but then again it requires disassembling the door trim and door panel and it seems like a lot of work to have it in place exactly. it's a piece of rubber and it deadens sound and whatnot. if you put it back in place and then glue the bottom (hooked) portion into it. it shouldn't ever move again and you'll never notice that it was glued
I did it to mine, and I'm going to have to do it again...to the other door panel :-(
Old Jul 19, 2009 | 05:29 PM
crazyasiantl's Avatar
Originally Posted by razzi
mine's doing the same thing. So far all i've done is jammed it back in and pray
x2
Old Jul 19, 2009 | 06:41 PM
ftLauTL's Avatar
Ya....It's an Acura
Originally Posted by crazyasiantl
x2
x3
Old Jul 19, 2009 | 06:50 PM
acutee's Avatar
Happened to mine too. Use just a little of clear sillicon at the corner and push it back in. You don't want it permanently glued in case it needs to be taken apart for other repairs.
Old Jul 19, 2009 | 07:25 PM
Rajca's Avatar
wham bam thank you ma'am
happened to my tl-s, what ever rubber part touches teh chrome trim, thats where i glued it, i used jb weld and after 3 chicago years. its still on their and holding strong
Old Jul 19, 2009 | 08:55 PM
twistedwedge's Avatar
6MT Someday..
The black paint is coming off my chrome piece like yours, but the gasket is still in place..for now
Old Jul 19, 2009 | 08:57 PM
jjashaa's Avatar
Avant Garde Wheels
lol.. i remember when mine did that..
forgot what i did.........
i think i just put a bit of super glue or something and just placed it back in.
Old Jul 19, 2009 | 09:53 PM
vdiddy210's Avatar
Sitting Fressshhh
super-77 sets but with a blow dryer it can easily be removed
SidhuSaaB
May 30, 2020 12:40 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
