Grriiiinnnnddd!!!!!
Old Nov 29, 2001 | 11:43 AM
ffracer's Avatar
3rd Gear
Question Grriiiinnnnddd!!!!!
Newbie here.
This morning, my daughter waiting inside the car, decided to start my wife's TL-S for her while she ran back into the house to get something. The only problem was-
THE CAR WAS ALREADY RUNNING!
My daughter turned the key twice for a good two seconds each time. Two questions:
Is a TL-S starter a common Acura/Honda product?
Should I have it looked at to make sure the "teeth" are not damaged?
Any suggestions is appreciated.
Kobayashi
Old Nov 29, 2001 | 11:49 AM
systek's Avatar
if it works, it works, if it doesnt, dont tell them what happened....!
Old Nov 29, 2001 | 12:08 PM
TUFF GONG's Avatar
Re: Grriiiinnnnddd!!!!!
Originally posted by ffracer
Kobayashi
Do you work for Keyser Soze?
Old Nov 30, 2001 | 12:42 AM
Austin519's Avatar
TUFF GONG:
HA HA HA HA HA!!!
"Do you work for Keyser Soze?"
Although it's Kaiser Sose I think...
Austin519
Old Nov 30, 2001 | 08:15 AM
pianoman41's Avatar
Although grinding is definitely not good for the starter, I doubt the two attempted restarts will cause a permanent malfunction of the starter. The teeth and the Bendix spring are designed to take some abuse. Obviously, if you have trouble starting the car (or hear funny sounds while trying to start), you may want the dealer to look at it. Otherwise, it'll probably be fine.
My '97 Maxima SE has a remote start option but does *not* have the anti-grind feature that keeps you from activating the starter when you stick the key in the ignition. When I first got it installed, I bet my wife and/or I accidentally tried to restart an already running car more than a dozen times. The car still starts first time every time and doesn't sound any worse the wear.
Old Nov 30, 2001 | 11:24 AM
ffracer's Avatar
3rd Gear
Thanks for the info..
On another note:
Sorry guys... I cannot disclose any information regarding my employer..(hehe)
Kobayashi
