Gauge Cluster problem...HELP!
Old Dec 20, 2002 | 07:57 PM
UA5-TL's Avatar
Unhappy Gauge Cluster problem...HELP!
Its only a minor problem but i've got a 01 SSM TL and i just swapped gauges w/ the 03 TL-P w/ 5000kms only problem is my outside temp says -----. have you guys that changed your gauges to TL-S ones had any problems w/ this???
Old Dec 20, 2002 | 09:03 PM
ArN 2000 TL's Avatar
Moderator Alumnus
you said you changed your gauges from '01 SSM TL' to '03 TL-P w/ 5000kms'. That should be an even changeover...one TL-P to another. Can I ask why you would do this?
Old Dec 21, 2002 | 04:42 AM
UA5-TL's Avatar
save clicks???
couldn't find TL-S from the junk yard...
now my problem is the outside temp says ----- :-( i need to know watz wrong
Old Dec 21, 2002 | 04:18 PM
Raheel's Avatar
Originally posted by UA5-TL
save clicks???
The all inspired Mileage Trick.. OK
Old Dec 23, 2002 | 02:49 PM
euzar's Avatar
7th Gear
So this means that anyone can just replace the gauges and therefore reset the vehicles mileage??? That's just ridiculous... Aren't these luxury cars supposed to have some protection? I mean, luxury car's values greatly on mileage.... I'm glad I buy new, another good reason not to buy used carsd!!!
Old Dec 23, 2002 | 05:41 PM
randomwalk101's Avatar
milage is logged by ECU...when you bring it into the dealer, they hook it up and you have say like 80K miles shows up and the gauge says you only have 5K miles...bam, federal crime...prison time buddy.
Old Dec 23, 2002 | 06:28 PM
Raheel's Avatar
But why the hell does the dealer care? I mean if you do it, than its your choice, you currently own the car.. Its diff if you sell the car and they find the prob and than take u to PRISON..
Old Dec 23, 2002 | 06:36 PM
Moderator Alumnus
You will get busted when the car is inspected if its already over 2 years old as well. The mileage registered on the inspection sticker will be more than what it says on the odometer (depending on what states us this method). Also if they car is ever taken to the dealer they can tell like randomwalk101 said.
Its not worth the aggravation is you ask me.....
Old Dec 23, 2002 | 09:32 PM
JensH
Guest
Posts: n/a
I think the original ,post was a call for help about a problem with a temp sensor.
UA5 you will need to verify that the wire going to the sensor underhood is in good order.The exterior air temp sensor is located below the hood latch ,it is a small usually black device about the size of a lighter.Please make sure it is actually plugged in.If it is you will need to remove the instrument panel and verify that the brown/white wire in the number 18 slot on the a connector is in good order.The a connector is the largest connector on the rear of the instrument panel.There is only one brown white wire in this connector.If this is in good order you will have to verify that the wire is good from the rear of the cluster to the sensor .If it is the sensor is probably no good.Due to the fact that there are multiple control units that depend on this signal unless you are experienced in handling delicate electronics I would advise you to refer this problem to the proper people.Jens
Old Dec 24, 2002 | 03:19 AM
UA5-TL's Avatar
Thx for your input JensH...i will check the temp sensor...
I dun think it doesn't matter if i change the gauges cuz everyone out there are some ppl that have changed to TL-S gauges anyway. i wanted to find some TL-S gauges as well. So does that mean everyone out there who changed to TL-S gauges will get busted? so its not just me...pls dun "YOU WILL GET BUSTED" at me...
I wish i found TL-S gauges but there wasn't any at the junk yard....and no one selling here....and none on ebay...
Old Dec 24, 2002 | 03:21 AM
UA5-TL's Avatar
plus in Canada we dun travel far distances to get anywhere...
i run about 30-50k a day
opposed to my dad who drives about 100miles a day in new jersey just to go to work
Old Dec 24, 2002 | 08:29 AM
shawhite's Avatar
i changed my gauges to tl-s gauges but it stayed on the orginal milage....
Old Dec 24, 2002 | 03:57 PM
they changed the gauge FACE..not the odometer and the whole thing!!! Get your facts straight!!!
Old Dec 24, 2002 | 06:34 PM
UA5-TL's Avatar
changing gauge Face is harder you dun wanna break the needles..i rather get whole thing
oh well....my business not yours
Old Dec 25, 2002 | 12:01 AM
asiankidd's Avatar
are you willing to sell your old gauge for cheap im working on a modification kit to make the lights like the lexus gauges..but i need a spare...please let me know thanks
Old Dec 25, 2002 | 11:48 PM
UA5-TL's Avatar
i'll see...only if i find some TL-S gauges maybe tho
but yea..i'm still wondering why my outside temp doesn't work thx...
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
brandnewcolony
Sep 12, 2015 10:39 AM
