Front bumper install problem
All Hail the Chief
I took off my front bumper to install the front body kit the other day and now the bumper doesn't seem to want to sit the way it did prior to me disassembling it.
The six or so metal clips/slots underneath the headlights that the bumper plastic aligns with....is the plastic supposed to go underneath or above the metal clips? When I place them under (which I assume they are supposed to) there is an unsightly gap in between my front bumper and the headlights. The gap became progressively worse as you move in toward the grill. I managed with much manipulation to place the bumper above those metal clips and while the fit was nice and snug against the headlights, there was a bulge in the bumper where it begins to wrap around the car.
I've always hated taking things apart from factory specs because IMHO you can never get things back the exact same way they were. I am SUPER anal about my car, so I want things back perfectly. But damn, I just don't understand how a big gap can magically appear just from reassembling the bumper.
Help!!!
Help!!!
Post some picture some so i can better understand what your talking about. I have took off my front bumper over dozen of time an still have no gap.
@ slide or die @
it happens to everyone on their first time.
The bumper's plastic thing goes INSIDE those clips, you gotta play around to get the bumper in there.
Solution:
I still had a gap, so i just rebended (manually is possible) that metal piece where the headlights/bumper mount, slide the bumper on and the gap is gone.
Solution:
That metal that hold front bumper in middle can be easy lift up two hand.
Any help????
@ slide or die @
very easy and very possible withought having to take off the whole bumper.
1) Take off the black clips in the engine bay with the flathead screw driver (pm and i'll show u pics of what they are if you dont already know)
2) remove the clips located under the bumper and the two/four bolts
(i say remove all just incase the bumper wants to break free, it'll just slide off instead of breaking, bending or cracking the paint)
3) unscrew the bolt located at the corner of the bumper meets the feder (under)
4) Pull out the side you want and leave it hanging
5) Kik it all you want from the inside to get the bump out
if u need details just pm me
2400 Watts in a TL...Why?
1 Post
SOLUTION.....
There is a bar mounted to the top of the bumper, only visable when the bumper is off.. This bar shares bolts with the headlights on either side and is also bolted down to the bumper in the center.
That bar sets the height the bumper will sit, I recently adjusted mine to eliminate the gap entirely.. It is very easy to do so it shouldn't take 5 min once the bumper is off. I believe it's a 10mm bolt.
And yes the plastic bumper sits int othe metal clips like you had thought, but if you leaned on one side of the bar when the bumper is/was off thebar could have moved causing the difference in the gaps..
Enjoy... it's a 15min fix.
Originally Posted by ResidualFreedom
SOLUTION.....
1 Post
get a pic with the bumper off andI can point it out to ya...
I can only find a far pic, it won't help much.
If you've had the bumper offyou can see a bar going across the entire front end from the outside of one headlightto the outside of the other. The bar shares screws with the headlights (under and to the outside of the lights) and also has a third point ofcontactin the middle of the bumper. At this third (center) point, the height of the bar can be adjusted and retightened to the desired height. The bumper rests on the bar across the entire bumper.
If that isn't clear try to post a pic, otherwise I'll keep looking on my harddrive for more pics.
Oakes
Wash & Wax
10-12-2015 11:17 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
