Fog light switch
Old Jul 2, 2001 | 06:58 PM
calvinpham74's Avatar
Question Fog light switch
Hi
I just bought a fog light switch from this site. I just wondering would it work for any fog light or certain kind of fog light? Is it easy to install it? Can you guy let me know. Thank you.
Old Jul 2, 2001 | 07:03 PM
Jens
Guest
Posts: n/a
You should be able to use it for any fog/driving light set that uses a relay to turn the lights on and off.You can pick up power etc. from the switches next to it.Jens
Exclamation
There are instructions for connecting the OEM switch to PIAA fogs - but maybe you can use that info for other fogs. But it works with PIAA's! Not sure if the instructions are in the FAQ section - if not I can post mr tl's diagram here.
Old Jul 2, 2001 | 07:14 PM
liutang's Avatar
You don't need the relay. You can connect the wires with $1 crimps from radio shack.
Old Jul 2, 2001 | 07:31 PM
Question Install
Do you guys have any instruction on how to install the Piaa fog lights to the swith? I did do the search, and I can't find the instruction anywhere? I will try to install at the end of this weekend. I really apreciated if you guys can help me out. Thank you.
Old Jul 2, 2001 | 08:00 PM
SinnedTL's Avatar
Ain't No Other...
Re: Install
Like TLDaddy said above, look for Mr TL's diagram on the search function, you should find it there...
Old Jul 2, 2001 | 11:08 PM
SLVR TL's Avatar
After the conversion, the links got screwy... I book marked it but the thread is gone. Anyway, here ya go...
You can directly hook (solder) the wires to the switch. Tranman actually figured it out.
"Looking from the switch on the side view, with the illumination on top (the way the switch goes in the slot), the top and bottom prongs go with black PIAA wire. The second from the top wire goes to white PIAA wire. The middle and the second from the bottom go to my red PIAA wire."
That's how I had mine wired and it works.
Old Jul 2, 2001 | 11:37 PM
You really shouldn't solder wires directly to switch terminals. It's better to solder the end of the wire (so it won't fray) and then crimp a small "tube-shaped" crimp connector to the end of the wire. The connectors help to dissipate heat that runs thru the wire and can heat up the switch. I got some at Radio Shack for 50 cents and they fit the TL fog switch terminals perfectly.
BTW - here's that diagram!
mada51589
Jan 9, 2025 04:40 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
