fog light question??
Old Jun 1, 2006 | 05:47 PM
rob0511's Avatar
hey i am just wondering if there is a way to put just the fog lights on and not the headlights? cuz the fogs only go on when the headlights are on, but i just want to know if any-1 has a modification for that? thanks
Old Jun 1, 2006 | 06:23 PM
Eedvl1999's Avatar
yeah its very easy, take a baseball bat or hammer (depends on your preference) and smash your headlights or remove bulbs from your headlights.
but seriously, i think there was few posts about that, try to do a search on it.
Old Jun 1, 2006 | 07:27 PM
VoLLy's Avatar
Meridian
Like this?
Follow this link:
http://www.acurainspired.com/forums/...showtopic=1034
VERY easy to do.
Old Jun 1, 2006 | 09:08 PM
Comet2404's Avatar
Flyin' and Drivin'
Sweet!!! I've been looking for that DIY for a while now!
Old Jun 1, 2006 | 10:48 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Thought you might like these pics based on your avatar!!
Old Jun 1, 2006 | 10:50 PM
VoLLy's Avatar
Meridian
^^ Are those 6500K or 8500k fogs?
Old Jun 1, 2006 | 11:11 PM
S1CK TypeS's Avatar
B A N N E D
nice im doing this tomorrow
Old Jun 2, 2006 | 06:09 AM
Bxscig's Avatar
You could also try this one.... I like this one better
http://www.acurainspired.com/forums/...showtopic=5695
Old Jun 2, 2006 | 06:14 AM
Bxscig's Avatar
Old Jun 2, 2006 | 09:44 AM
Bxscig's Avatar
Those are 6000K Philips and I responded to ur PM about the parts, it probably looks harder than it is actually to do.
Old Jun 2, 2006 | 09:48 AM
c0v3rr1d3's Avatar
just don't start and run your car when you have the fuse pulled, else you'll most likely have to reset the srs and check engine light
Old Jun 2, 2006 | 11:30 AM
Bxscig's Avatar
Yup.
Dont have the keys in the car when you do this or disconnect the battery BEFORE you begin.
Old Jun 2, 2006 | 12:13 PM
VoLLy's Avatar
Meridian
Yup.
I PM'ed you back, check AI.
Old Jun 2, 2006 | 06:09 PM
TypeSDriver's Avatar
Follow this link:
http://www.acurainspired.com/forums...?showtopic=1034
VERY easy to do
I just did this myself after seeing it posted for the umpteenth time...great stuff! It took me all of 15 minutes (max) and now I'm all set. That is a great write up with step-by-step instructions with pictures.
Old Jun 2, 2006 | 09:24 PM
Here they are...I can't wait to go out at night and check them out. I can't tonight because it's pouring!
Old Jun 6, 2006 | 01:01 PM
OnlyStephen's Avatar
When you mod, do they still turn off/time out as the lights normally do, when you exit the car or must you use the switch everytime?
Old Jun 6, 2006 | 01:37 PM
c0v3rr1d3's Avatar
no they still turn off/time out
they will always go out as soon as you pull the key out of the ignition.
So if you have just your fogs on and turn off the car and pull the key they go off cause now the fog light switch thinks your headlights are off therefore won't turn your fogs on.
similary with park lights on, and with full headlights on it works as if you never did the mod at all. Similarly when u put on your high beams the fogs still go off
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
