Fog light mod (Alternate version)
Old Apr 20, 2004 | 01:26 PM
Bxscig's Avatar
This is for the 02/03 TL Models.
Here is the pinout/wiring color code for the fog light switch for the 02/03 models.
I had tested the states of these wires under the following conditions:
Blue w/ Red stripe = +12V when button is pushed and headlights are on
Whie w/ Red stripe = +12V when headlights are on
Red w/ Black stripe = +12V when parking lights are on
Provided by Pianoman41
1. White/Blue - Ground side of indicator light (green light that shows fogs are on)
2. Blue/Red - Power to passenger side footwell relay
3. White/Red - Power from headlight switch
4. Red/Black - Power from taillight relay
5. Red - Connection to dash light brightness controller
Now the fog light mod has the white/red and the red/black tied together. I assume that by hooking these two together, it fakes the switch into thinking that the headlights are on so that you can turn on the fogs. NOW! What if you want the fog lights on without the parking lights on??
Would the solution be to supply the white/red wire (headlight switch) +12Vs? Possibly from a source that is HOT when the key is in the ignition?? Will the white/red wire be enough or will the red/black wire also have to be supplied 12Vs?
One more question, if that solution suggested above works, should diodes be inserted?
Old Apr 21, 2004 | 09:17 PM
Bxscig's Avatar
Well it is done, and it works. So it works without the parking lights and it doesn't flash with the parking lights when you unlock the car like the original mod did if you left the fog lights on.
Old Apr 21, 2004 | 09:51 PM
Eternal TL2k3's Avatar
so how did u get it done?
Old Apr 22, 2004 | 05:34 AM
Bxscig's Avatar
Just give the White/Red wire +12Vs. I gave it +12Vs from the fuse box that gets power when the key is in the ignition. It just fakes the switch into thinking that the headlights are on when the key is in the ignition. Before, the Red/Black wire is +12Vs with parking lights to illuminate the button.
I used a wire tap into the and ran a wire to this add-a-circuit (thick red wire) i had in the fuse box for the footwell lighting just to test for now. I'll find a more permanent location soon.
Old Apr 22, 2004 | 05:38 PM
Bxscig's Avatar
Old Apr 22, 2004 | 09:25 PM
NYDesi80's Avatar
Dam, what camera did you use for that HID Picture, you caught the 6000K lighting perfectly!! No matter how much I try I can never do that!!
Old Apr 22, 2004 | 10:04 PM
Bxscig's Avatar
haha really? Sony DSC-S85 lol
Old Apr 22, 2004 | 10:23 PM
`ill*tl's Avatar
You suck with a digi.. :p BTW Bxscig, sweet mod. But doesn't it look better when your corner lights are on as well?
Old Apr 22, 2004 | 10:45 PM
NYDesi80's Avatar
I like this way better, by doing this mod, there are two pluses. One is that you have a choice in weather you want the parking lights on/off with your fogs, and if your heart desires that, just switch them on. Second, I often forget to turn the fog light switch off and when I lock and unlock my doors the dam fogs blink on and off. And since I have HID's thas unnecesary wear on the Ballast. So this mod would eliminate that problem too. To me its, the way to go!! Good Job Bxscig!!
Old Apr 23, 2004 | 05:46 AM
Bxscig's Avatar
The only reason I didnt do it orginally was because I didnt like the parking lights on. It just didnt look right to me... dunno...
At least now I can choose to have it on with my parking lights and not with headlights on.
Also liek NYDESI80, I wouldn't want to have it pulse on and off like that when unlocking (if they are left on) especially with HIDs in there. I don't think it can be healthy for it.
Old Jun 6, 2005 | 04:29 PM
Bxscig's Avatar
Super old but updated... works better than it did before. Now you can have your fogs on and crank w/o them shutting off.
Instrumental Panel Fuse # 9 Driver side to Add-a-circuit to diode to white/red wire on the harness on the fog light switch.
You could also use these for DRLs if you like since the parking lights dont come on with it.
Old Jun 6, 2005 | 04:35 PM
Bxscig's Avatar
Old Jun 6, 2005 | 09:22 PM
gohan's Avatar
Hey Gee, you think you can do this mod for me at the BBQ meet?
Old Jun 6, 2005 | 10:22 PM
Bxscig's Avatar
Actually even before if you like, u need to get the mini add-a-circuit, and a diode. i would need an outlet too probably but I could always bring an inverter.
Old Jun 7, 2005 | 12:14 PM
gohan's Avatar
Would you mind going to get the stuff with me? Cuz I have no idea what to get. Maybe we can go to Home Depot before the others meet up?
Old Jun 7, 2005 | 01:57 PM
Tappy116's Avatar
02 TL-s WDP
Bxscig, The funny thing is that I was looking at this thread a couple of days ago and was thinking about posting to see if you had an update.
P.S. You really know your Shyt.
Pics of your fuse box and harnse if you can. Thanks!
Old Jun 18, 2005 | 05:52 PM
khoifl's Avatar
Bxscig, could you please post pics of your fuse box and harness? Because I followed your instruction and lost when you said something about an outlet and an inverter. I haven't have any mod to my foglight so if you will, could you explain in details the mod please? Thank you.
By the way, your mod is cool.
Old Jun 18, 2005 | 11:39 PM
Bxscig's Avatar
the "i would need an outlet too probably but I could always bring an inverter."
was meant that i could bring an inverter in the car so i can solder the wires together at the meet.
The mod is basically, add the add-a-circuit to fuse for instrumental panel (i believe fuse #9) and then add a diode with the silver strip pointing away from the fuse box then a wire from that to the fog light harness (white/red) wire.
Old Jun 18, 2005 | 11:52 PM
Bxscig's Avatar
I'll see if I can get some pictures
here is 1 of the harness
the red-blue butt is the add-a-circut part
Old Jun 24, 2005 | 12:02 AM
khoifl's Avatar
Question Sorry to bother you Bxscig
Could you please post your pics somewhere else because every time I am on. AI is not up. Do you have a particular part # or spec for the diode or anything will work? Can I get add-a-circuit part and a diode from Radio Shack or I have to go to a special place?
Old Jun 24, 2005 | 01:34 AM
Bxscig's Avatar
I'll try to post the pictures some where else but basically here is the shopping list
radio shack:
those red taps, i believe like 4 for $0.98
diodes, i believe it says 7004 or something like 4004 and comes in a package of 2 for about $0.75
auto-store:
autozone seems to have the cheaper prices for me
green/black package, MINI-add-a-circuit for about $7 and it comes with a bunch of little fuses.
wire crimper from some where
Old Jun 24, 2005 | 08:05 AM
mezzerTL-S's Avatar
New ride...Acura MDX 2013
This my seem like a stupid question but I need clerification, with this mod I can still turn the fog lights off with the button when the car is running yes or no?
Peace, Jeff
BTW bxscig can you post pics of the fuse box so I can see the hook up
thanks
Old Jun 24, 2005 | 08:39 AM
demolition_x's Avatar
Agean Blue Bishes
do the fogs still shut off the the high beams?
Old Jun 24, 2005 | 10:50 AM
Bxscig's Avatar
Peace, Jeff
thanks
The fogs WILL ONLY come on when the button is on with or without the car running BUT the KEY MUST be in. I'll get some pics in a few
The fogs still shut off when the high beams are ON, but not when flashed which is like normal. I wanted to fix this for a while now but I have been just too lazy to do it. I know what I need to do, just a matter of going and testing it.
Old Jun 24, 2005 | 10:51 AM
Bxscig's Avatar
gohan, whenever you get a chance just let me know... wednesday mornings/afternoons or even fridays mornings
Old Jun 24, 2005 | 01:44 PM
mezzerTL-S's Avatar
thanks bxscig, i'm doing that very soon
Old Jun 24, 2005 | 01:52 PM
gohan's Avatar
Could you do it this coming Wed. morning (6/29)? Thanks.
Old Jun 27, 2005 | 10:42 PM
Bxscig's Avatar
Tyzing, add-a-circuit to diode ---|>|--- to white/red wire of fog light harness (pin 3 from what I recall)
Old Jun 28, 2005 | 12:01 AM
Tyzing's Avatar
Ok, I'll post some pics of what I have already, it wont be until WED. b/c i'm going out of town for a All-Star game....i'll be back and we'll try and figure this thing out....I think I just need to figure out the diode b/c i did everything else right....thanks for all your help
Old Jun 29, 2005 | 09:18 PM
Tyzing's Avatar
Foglight mod fixed....
Guys you gotta do this mod, it's 100 times easier then the other and you have the best of both worlds....and not to mention if you do get in a hang up bxscig is there for any help he can be, thanks for the help man and i'll post pics if anyone would like...let me know
Old Jun 30, 2005 | 05:10 PM
Bxscig's Avatar
I did Elegant's car today and here are some pictures that I took for the install.
Old Jun 30, 2005 | 05:18 PM
Bxscig's Avatar
This is what a diode looks like and how it works, current only flows from Anode to Cathode, the silver bar shows you which is the cathode side.
That is my diode connected to some wire to the left and to the right (Anode and Cathode sides) with some shrink wrap over it. Electrical tape will be fine as well. I had soldered it but you can just twist it together.
Here it is connected to the MINI add-a-circut crimped to the Anode side of the wire to the blue thing. I used a 3 AMP fuse, probably more than needed but it is fine. Notice where it is added, the instructions of the add-a-circuit will explain.
This is the fog light switch harness and swtich. I had to undo the original fog light mod and taped up the two wires.
Just another shot
Driver side Fuse panel before I remove anything.
Drive side Fuse panel after I remove the fuse #9 instrumental panel slot. The one below it is the ACC one. Both are 7.5 Amps.
With the removed fuse I just place it into the other slot of the add-a-circuit. Again the instructions of the add-a-circuit will explain.
The add-a-circuit installed into the fuse box. I just plugged it back into the fuse #9 slot. Just that easy.
Close up!
The other side now of the diode, Cathode side, now you just use a tap to tap into white/red wire which was used originally for the first fog light mod. So you crimp the black wire extended from the cathode side of the diode to the white/red wire.
Close up of how it is crimped together.
Now you are done!!!!!!!!!!!!!
Old Jun 30, 2005 | 08:16 PM
Bxscig's Avatar
The diode is just to prevent the the fogs from powering ur instrumental panel even after u remove the key.
I had it happen to me a few times when I used to have it attached to slot #8, the ACC/Radio because when the radio is on and the fogs are on once the key is out..... the radio remains on.
Old Jul 4, 2005 | 09:57 AM
mezzerTL-S's Avatar
i was away for the weekend and just found this, and wanted to thank you for the pics and great write up, definately doing this very soon
Peace, Jeff
Old Jul 5, 2005 | 04:59 PM
mezzerTL-S's Avatar
hey bxscig, what are the specs of the diode, first of all The Source (formerly known as Radio Shack) doesn't have any, the lead you gave me goes to the guys voice mail so I've found another source and they are asking me the specs and I don't know them they have a bunch in stock but I want to buy the right one, if you can let me know, much appreciated
Jeff
Old Jul 5, 2005 | 05:15 PM
Bxscig's Avatar
http://www.radioshack.com/product.as...%5Fid=276-1103
Old Jul 5, 2005 | 08:08 PM
Bxscig's Avatar
I searched The Source and it sucks... nothing. 1N4004 Try asking a place for this.
Old Jul 6, 2005 | 10:07 AM
mezzerTL-S's Avatar
thanks, I checked the Source as well and werd they suck, I didn't think that getting a diode would be so difficult , I made a few phone calls and possibly have a line on one hopefully thanks for your help Bxscig
Jeff
Old Jul 6, 2005 | 10:12 AM
Bxscig's Avatar
I can send you one, cost me like 75 cents and another 75 cents postage.
Old Jul 7, 2005 | 09:41 AM
mezzerTL-S's Avatar
Thanks but not necessary I finally found an electronics place that know their shit and got the .75cent diode. I'll post pictures once I install the 6000K HID kit that I ordered today . Thanks for helping out an electronics noob, much appreciated.
Jeff
