Flush Brake Fluid? Help
Old 09-28-2007 | 01:29 PM
CHEWKNOW's Avatar
How do I do it and what order do i go in?
If im flushing do I completely flush from the first bleeder until its clear then move to the other ones and repeat?
Old 09-28-2007 | 01:46 PM
AMGala's Avatar
Lamborghini Aventador FTW
OK, you've been on the forum long enough to know how to search. Let's see if you can find the thread that gives the directions for this.
https://acurazine.com/forums/showthread.php?t=162260&highlight=brake+flush
Old 09-28-2007 | 01:48 PM
CHEWKNOW's Avatar
haha..i did search! I searched for "Flush brake fluid" and just "brake fluid". I didn't get any clear cut threads.
Old 09-28-2007 | 01:51 PM
AMGala's Avatar
Search "brake flush", or just look closely at my post above. It's as clear as black and white.
Old 09-28-2007 | 01:53 PM
CHEWKNOW's Avatar
SOOOOOOOOOOOOOOOO SNEEEEEEEEEEEEEEEEEEEEEEEEEEEKY. haha...you can close this thread. Thanks bro...just searched the wrong way i guess.
Old 09-28-2007 | 01:57 PM
dnd2984's Avatar
Man I looked at your DIY rotor and pads. Now u are asking a question
OK I stared a threard on Brake rotors. But this is what I did. I got Synpower brakefluid. Remove old fluid with turkey baster and topped off master cylinder with new fluid.
Bought the one man bleeder kit from Advance auto for 7 bucks. Started with the driverside, hook up clear plastic hose to bleeder valve, open the bleeder valve and pump brake about 5 to 6 times. Top off fluid and I pumped the brake another 5 times. Close bleeder valve and move onto passenger side front, passenger rear, and driver rear last. Make sure you keep the master cylinder topped off each time.
Old 09-28-2007 | 01:58 PM
AMGala's Avatar
Haha
Old 09-28-2007 | 02:03 PM
CHEWKNOW's Avatar
haha...Just triple checking. I didn't flush the system when I changed my stuff. Like an idiot i was in such a rush so didn't do it and im doing it this weekend. Like i said..just triple checking before I do something wrong.
Old 09-28-2007 | 04:08 PM
01tl4tl's Avatar
Make sure to flush a bit more after its clean and clear- then refill master cyl, cap tightly and move to next one
the order stated is correct for TL
LF driver front- then clockwise around the car LF RF RR LR
I like Valvoline Synthetic 1 quart 6 bucks is plenty of fluid- you can't store it- so use it all up flushing the lines~
My new 1 man system didnt work so we did the old school pump em up and hold- open bleeder- fluid out- close bleeder
Make sure not to push pedal more that 3/4 of its travel to the floor
A small block of wood- 2x4 under the pedal will prevent seal damage
Buy wife new turkey baster when done!
SidhuSaaB
05-30-2020 12:40 AM
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
LeVeL
10-18-2015 04:19 PM
lanechanger
10-13-2015 10:56 AM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Flush Brake Fluid? Help
