Fan shroud
Fan shroud
So i had to get a new radiator and upon installing it i noticed it made some noise. I took it into a mechanic and he said it was because of the fan shroud rubbing against the power steering. Any fix to this ?
ck your installation, is rad stting in its mounts?
is it exactly the same size as original one?
can you see the wear marks- where its rubbing?
I didn't install it but i watched my friend do it. I think we messed up on the mounts or something because i looked at the wear marks and about a 1/4" of the tube has been worn through.
Mr.Helpful Diagram
To clear up the confusion going on here, Take a picture of the fan and post it here.
Sounds to me like it wasn't installed correctly
New rad installed, but now fan shroud is rubbing
If you're sure that ya had the correct rad to replace the old one with, then apparently it's not fully seated and needs to be re-positioned. Maybe one of the rubber isolators at the bottom got misplaced or lost. Recheck the rad's installation.
good call 3.2, those rubber things in the mounts go missing and now you have clearance issue
