exhaust leak...
Old May 15, 2017 | 08:35 AM
BigDog263's Avatar
exhaust leak...
so i just replaced my oil pan this past weekend and to do so i had to unbolt the down pipe from the headers. well all is good except i have a check engine light on and a exhaust leak out of both flange attachments should i just get new gaskets? if not what else would solve the problem to also make the check engine light go off
Old May 15, 2017 | 08:37 AM
Yes, new gaskets maybhelp. Unless you cracked it downstream
Old May 15, 2017 | 08:43 AM
BigDog263's Avatar
which one exactly because the flange from the down pipe looks like part no. 31645 but on there diagram it says to use part no. 31377.... im so confused
Old May 15, 2017 | 08:48 AM
What's diagram are you using? Those aren't typical Honda/Acura part numbers
Old May 15, 2017 | 08:50 AM
BigDog263's Avatar
Walker. they have a diagram for products they sell is a 1999-2003 acura tl exhaust diagram.
Old May 15, 2017 | 09:00 AM
Iggy's Avatar
my experience with those gaskets is to use OEM which are fairly inexpensive. The aftermarket ones don't seem to fit right.
Old May 15, 2017 | 09:40 AM
frankjnjr's Avatar
"ditto" after resealing my oil pan, i used aftermarket gaskets for the header pipe and the left side would not seal properly. after installing OEM gaskets, all was good.
Old May 15, 2017 | 11:15 AM
BigDog263's Avatar
so im guessing i would have to order the gaskets from Acura??
Old May 15, 2017 | 11:19 AM
They may be in stock on Amazon.
Check out www.oemacuraparts.com
Old May 15, 2017 | 01:30 PM
BigDog263's Avatar
thank you for the advice guys!
Old May 16, 2017 | 08:40 AM
Kris9884's Avatar
New gaskets OR reuse the old one and use some copper gasket spray. I used copper spray on all of my aftermarket piping for my G and it sealed up perfectly.
