Er-E1 failure error message
Old Oct 24, 2006 | 05:41 PM
vzuptnguyen's Avatar
B A N N E D
my 6 disc cd changer was working great. then all of a sudden, i put a disc in that i always have put in. it froze and put that message. now i cant even get disc out.
troubleshoot ive done is turn on and off car. thats it. i think ill give it an hour or two and check again.
anyone know or have this problem before?
Old Oct 24, 2006 | 06:11 PM
PiMpiN wHITe Cl-S's Avatar
try unpluging the antenna on the back of the radio and re-enter the code..see if that works.
Old Oct 24, 2006 | 06:46 PM
B A N N E D
ahhhhhhhhhhhh
that takes like half an hour.
Old Oct 24, 2006 | 06:49 PM
took me 5 min. just take the driverside trim and panel off and should have access to the plug.
Old Oct 24, 2006 | 06:52 PM
PenancE's Avatar
i had it, cuz the disc isnt properly put in, u were able to see the disc sitting there, near the bottom of the opening, what i did was get another cd, and try to push it up, and it came out, and put it back in
Old Oct 24, 2006 | 07:07 PM
B A N N E D
yea i figured it was about the disc.
Old Oct 24, 2006 | 07:12 PM
PenancE's Avatar
flip open that cover piece that closes/opens when u put a disc in, and see how far wedged the disc is, usually when it happens with me, u can see it on the lip of the opening
next time when puttin in a cd, dont force it, and keep it straight with the unit
Old Oct 24, 2006 | 07:13 PM
Oh, I guess it read it wrong. I thought you were have trouble with the radio.
Just get a new headunit. I had that happen to me all the time.
Old Oct 24, 2006 | 08:01 PM
B A N N E D
i see whats wrong now. when i open the door cover. i see a thin metal piece that is lifted up. i see the problem but dont know how to fix it. ill post a pic later 2nite.
damn, wonder how much this will be at dealer
thanks for all your help penance and white cl-s, i really appreciate it.
Old Oct 24, 2006 | 08:02 PM
B A N N E D
oh penance, i want to know if i had exact same problem as you. name your symptoms
i can eject any disc, at first it let me eject a disc. then it wouldnt do it anymore
Old Oct 24, 2006 | 08:10 PM
drcookie's Avatar
I have the same issue on CD-2 and CD-3. They sometime work but most of the time, I would get the same error message. Does it qualify for replacement?
Old Oct 24, 2006 | 08:34 PM
PenancE's Avatar
like the only time i got that error msg is when the cd wasnt put in properly, try changing the disc, to disc 6 or something to see if it can re align it self, but honestly thats what i did, put another cd in it and pried up...how far in is the cd in the unit? take a pic..
Old Oct 24, 2006 | 08:37 PM
Topher707's Avatar
05 Acura TL: a-spec
I have been having the problem where the 6 disc changer all of a sudden decides to stop playing, then displays the ER-E1 message when I attempt to play a CD. When I try to eject the disc they dont come out. This problem has been going on for about 3 weeks. I have found that if you hold down the eject button, you hear a beep. Then like the next time I start the car, all the discs eject themselves... so I really dont know what is wrong or how to fix it.. but i have heard replacement/repair is VERY expensive.
Old Oct 25, 2006 | 01:58 AM
B A N N E D
calichris: when you do what you said you did, does it work after?
penance: i cant switch disc, it displays the same message, and i dont see any cd in there.
i was about to pull out the radio system today and try to fix it myself(which would end up in $300 down the drain) haha
Old Oct 25, 2006 | 02:01 AM
drcookie's Avatar
I have exactly the issue that you described. The CD would play and stop and display the error message. It would play again after leaving it off for a day.
I have extended warranty for my Acura and I am not sure if the warranty could cover the replacement. I need to start reading the small prints.
Old Oct 25, 2006 | 08:38 AM
B A N N E D
wow. this seems to be an undiscussed universal problem.
i dont think i see any disc to push in.
Old Oct 25, 2006 | 08:39 AM
us000011's Avatar
Old&CnL
Talking Bang on it
When I went to sell my 2001 CL and remove all the discs, I got the same code, and nothing would come out.
My solution: Bang on the side of the console in frustration. It fixed it, and all discs came out. Dust and dirt in the changer can cause the problem.
Now I have a 2003 TL-S, Ant-met., no problems so far.
Old Oct 25, 2006 | 10:04 AM
xdxlx's Avatar
same thing happened to me, the error message. but i just took out the cd, and pushed it back in and everything was fine after that.
Old Oct 25, 2006 | 04:42 PM
B A N N E D
no, theres no CD lodged, i think they are in placed.
i took it to a professional car radio shop and he told me the aluminum piece is the CD tray. he said it is bent somehow and he has to replace that part for about 300 dollars...the radio cost me 250.
ahhhh. so now im try to take the radio apart and bend tray in place. anyone think i should go ahead with this?
Old Oct 25, 2006 | 04:43 PM
B A N N E D
did any of you guys noticed if a tray was bent
Old Oct 25, 2006 | 04:56 PM
drcookie's Avatar
Have not checked mine yet.
Old Oct 25, 2006 | 05:05 PM
B A N N E D
if you guys can, can you please check for me by opening the door and see if an aluminum sheet is on top or bottom. or wherever it is.
Old Oct 25, 2006 | 05:07 PM
why not just buy a new headunit rather than repair?
Old Oct 25, 2006 | 07:11 PM
drcookie's Avatar
Will update you tomorrow.
Old Oct 25, 2006 | 07:18 PM
B A N N E D
well another 200 is something i dont have right now. and this is such a little fix, its just the effort that is involved in removing everything.
Old Oct 26, 2006 | 10:54 AM
drcookie's Avatar
update:
I did not notice any bent on the aluminium plate. Unfortunately, I could not find my flash light, so, I won't be able to inspect in detail. Will try again tonight.
Old Oct 26, 2006 | 03:42 PM
B A N N E D
thanks for helping, ill get a flash light and take a pic soon.
Old Oct 26, 2006 | 09:08 PM
B A N N E D
is sloping upward from left to right. i try to push that shiny thing down but it keepts popping up.
can anyone check if that should be down or up please. thank you.
Old Oct 27, 2006 | 11:22 AM
PenancE's Avatar
thats the cd eh, it looks like it should be up
Old Oct 27, 2006 | 11:48 AM
Billy Sacco's Avatar
Kilos of yayo in
You might need to take the head unit out of the dash and completely take it apart. My stock head unit did the exact same thing. Quit ejecting disks period and before that it was giving that error all the time but then just quit ejecting or playing anything. When I replaced the head unit I had to hack it apart just to get my cds out.
Old Oct 27, 2006 | 04:59 PM
B A N N E D
did u get it to finally work?
Old Oct 27, 2006 | 08:26 PM
BillySacco's Avatar
No I never got the stock head unit to work again. I had to open it just to get my CDs out because they would not even eject. It sounds like you are on the right track with trying to bend that metal piece back into shape though which I could offer more help but I never got the dang thing to work. I know you said you can't afford another head unit but I would just go that route, there are many good pioneer head units out there for pretty cheap.
Old Oct 28, 2006 | 03:04 AM
B A N N E D
yea, but i like the stock look ( more luxurious ) plus with all this self amped speaker crap (which is nice) im sure i cant get a head unit without re wiring or something.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rockyboy
Sep 25, 2015 10:44 AM
