Entertainment Unit temp install
Old Jun 30, 2005 | 06:30 PM
Acura=the_need_4_speed's Avatar
hey im kinda a newb to mods right now but i have just got my hands on a dvd mp3 entertainment unit with a 7' monitor...i was just wondering for like just to test the unit what is needed to be done....like what to remove and look for to test it...if anybody could tell me an easy way to do this, would be much appreciated
Thank You
Old Jun 30, 2005 | 06:35 PM
brakejob's Avatar
:brakejob:
um, just wire 12v and ground to it and turn it on, if you want to check speaker output get a crappy 2 dollar speaker from walmart or something...
Old Jun 30, 2005 | 06:55 PM
wire 12v from the car?? if so how do i do that..what would i have to remove/ do?
Old Jun 30, 2005 | 08:08 PM
brakejob's Avatar
:brakejob:
if you just want to test it you could feasibly run 12v in from the battery, and run a wire for ground, then setup a crappy speaker and test each channel
but im guessing you're not too knowledgeable with electronics...
do you want help installing this, or just testing it to see if it works? if it's the former, then we have a lot more to go over... if it's the latter and you just want to test and make sure its a working unit, then you need to somehow do the following
power it
turn it on
hook a speaker up to it
assuming you want to test it before ripping the dash off and installing it, you're going to need some wires and a speaker.
the quickest way to do it is to wrap a wire around the negative terminal of the battery , do the same for the positive, and hook these to the corresponding wires in the head unit. be careful because you're running totally unfused, and this is all at your own risk
turn the HU on and make sure it powers up. hook in the speaker to a channel and turn the volume up, make sure some sound gets to the speaker. then move the speaker to another channel and repeat, just to ensure the HU sends audio to all of the outputs... maybe put a DVD in too to see if it works, etc...
Old Jun 30, 2005 | 08:34 PM
thanx for the response....at this stage i just wish to test the unit..so if u could tell me how i can go about testing the unit to see if it works...you say that i can connect to the battery but from the cables with the dvd player n monitor i do not see how you can do this....if you could help me out that would be great
Thank you
Old Jun 30, 2005 | 08:47 PM
brakejob's Avatar
:brakejob:
so is this like a separate dvd / monitor combo... crap I thought it was a replacement head unit with a dvd player and monitor...
well what model is it, and what are the connections?
Old Jul 1, 2005 | 12:05 PM
its a kia dvd entertainment system like a top ceiling mount one (dont ask), most of the installation cables that came with the unit look like ribbon cables and rca inputs & outputs (came with FM modulator if that helps anything)...i was just wondering how i could connect it to my car just to see if it works....and i know im gonna have to remove my dash and take out my deck (kenwood KDC-X679) so advice on how to take that out would be much appreciated
Old Jul 1, 2005 | 02:08 PM
here are some pictures
http://spaces.msn.com/members/donste...&_c=photoalbum
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
NSolace
Sep 3, 2015 08:02 PM
