Engine Ticking Problem
Old Jan 31, 2003 | 10:04 AM
Zed's TL's Avatar
I have noticed a loud ticking noise coming from a solenoid under the hood of my TL. I hear the noise inside my car in either neutral or park. The noise persists whether the climate control is on or off. I only use 92 or 93 octane fuel, so it is not detonation.
I have traced the ticking to a solenoid next to the firewall, directly behind the brake fluid resevoir. The solenoid has an electrical connection on one side and a hose connection on the other. The switch is marked DENSO 211 PCS33.
The question is, is this normal or is this switch about to pack it in?
I invite your comments.
Old Jan 31, 2003 | 10:05 AM
numbaonexstunna's Avatar
i have the same thing..............it gets annoying.
Old Jan 31, 2003 | 10:09 AM
fla-tls's Avatar
On the way!
Mine does it too... always has...
Old Jan 31, 2003 | 11:09 AM
Zed's TL's Avatar
Have either of you guys had the dealer look/listen to the ticking switch?
Old Jan 31, 2003 | 11:45 AM
Check the connection of the plug going into your solenoid. If the connection is a bit loose, it could cause it to constantly engage/disengage, unless it was designed to do that.
Old Jan 31, 2003 | 11:46 AM
jean's Avatar
My 2002 TL does the same also.
No mech malfunction observed...
I believe this is normal.
J
Old Jan 31, 2003 | 12:43 PM
Zed's TL's Avatar
johnnyb_s: The electrical connection is solid; it is an aircraft type connector.
I should mention that everything works. I was just concerned that a noisy solenoid, is a sick solenoid.
jean: Did the dealer tell you the clicking is normal?
Old Jan 31, 2003 | 01:33 PM
jean's Avatar
Well, I think if the solenoid was mal-functioning, you wouldnt be firing on all cylinders.. your gas mileage would be the s**ts and not to mention a severe decrease in power. Not to mention the -check engine- light would scream at you. I means its a solenoid... your engine needs it to be working properly, otherwise the car would be flat.
The last time the dealer saw my car was for an oil change and a determined inspection. No problems found.
If your car zips along nicely.. doesnt hesitate or have pile of black smoke out the back.. I would say - relax and enjoy the car-
Jean
Old Jan 31, 2003 | 02:37 PM
Zed's TL's Avatar
Merci Jean
Old Jan 31, 2003 | 04:26 PM
edgalang's Avatar
Purchased: April 28, 2001
I have the same thing too. I thought it was my fault and that I may be choking the collant line after my CAI installation (since you had to replace one of the hoses). Thank God it's normal.
Old Jan 31, 2003 | 06:23 PM
fla-tls's Avatar
On the way!
I originally got worried because I thought it was a noisy valve. But thankfully - it's not.
Old Jan 31, 2003 | 06:56 PM
jean's Avatar
Originally posted by Zed's TL
Merci Jean
Avec plaisir cher Monsieur...
Old Jan 31, 2003 | 09:37 PM
BLEXV6's Avatar
My 2002 does it as well, as does my 1998 V6 Accord.
Old Feb 1, 2003 | 04:26 AM
cheezthis's Avatar
4th Gear
Crazy thought...could it be your injectors? Honda injectors have known to generate quite a "tick" and such. I know that they're loud on my GS-R...loud on my dad's Accord V6 and my mom's TL.
Old Feb 1, 2003 | 08:04 AM
fla-tls's Avatar
On the way!
No, it's the solenoid. If you grab it with your hand you can actually feel it tick.
Old Feb 2, 2003 | 05:12 PM
Zed's TL's Avatar
Engine Ticking Revisited
Thanks for all the replies. If it were not for you folks I would have been off to the dealer.
I was able to isolate the solenoid as the source of the ticking by holding it in my hand. Now that it has warmed up a bit, the solenoid is silent.
I guess I will have to find something else to worry about--like the paint.
Old Feb 2, 2003 | 06:09 PM
fla-tls's Avatar
On the way!
Glad we could help. It was my experience that the paint requires a few months to cure before it's hardened fully. After 6 months or so (here in FL), the paint seemed pretty decent.
Billu99tl
Sep 13, 2015 11:30 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
