engine problem
Old Feb 13, 2005 | 10:51 PM
chilifrost's Avatar
engine problem
Today something strange happened to my car for the first time. I had been driving the car, stopped to buy some groceries when I came back I started up the car, it started to shake a bit then just turned off, did that about three times untill it finally stayed on, but the engine light came on. :wtf: Car is a 2000tl with 34,566 miles on it, new battery. :bigcry: Anybody know what might be the problem.
Old Feb 13, 2005 | 10:59 PM
AustNMike's Avatar
Hmm...Is that right??
did you fill up gas recently??
Old Feb 13, 2005 | 11:01 PM
chilifrost's Avatar
Nope about 2 weeks ago, only a weekend car.
Old Feb 13, 2005 | 11:20 PM
AustNMike's Avatar
i dont know.....changed the fuel filter yet?? even tho lo miles, maybe aged and clogged....also, if only weekend car, then sometimes when a car sits for a while, there are dirt particles and stuff that collects/settles in the tank and system that may cause "clogging" somewhere....i just feel like its fuel related...
if i couldn't spend any money, i would take it out and get on the highway and romp her up to about 90-100 or more *safely* and just drive her more....she needs to be used......thats if it was my car...what do I know?...
Old Feb 13, 2005 | 11:22 PM
alleyesonmeee's Avatar
MIA
It could be just from the car sitting too long without being driven, especially if you live somewhere where it is cold right now. Go to Autozone/PepBoys and get a code diagnostic run and see if it is throwing any errors.
Old Feb 13, 2005 | 11:28 PM
Pure Adrenaline's Avatar
Dragging knees in
Get the code scanned, then go from there. AutoZone offers free scanning.
By the way, holy low miles on a 2000. Mine's an '03, and I have nearly identical mileage on her.
Old Feb 14, 2005 | 07:59 AM
Faizalstar's Avatar
TLStar
my car has done that a good few times as well, thought it was the battery at first but it's not. i have over 70K and it does that, next time it happens just floor it a few times till it starts ok but usually once u can get it into drive w/o shutting off and start driving it's ok. if u do a search on this site you'll see others with similiar problems like this and some suggest that it may be a valve called "E--" something. should be covered on your warranty, if not i hear it's about $1000 to get fixed. haven't done anything with mine since it's out of warranty. good luck.
Old Feb 14, 2005 | 08:38 AM
Shift_it's Avatar
Sounds like it has to be someing along the "Not getting fuel" catagory. Check to see if it has a clogged fuel filter,, if not check the fuel pump. If none,, try reset the EMU and see if it does it again
Old Feb 14, 2005 | 09:25 AM
Faizalstar's Avatar
TLStar
when i called acura a while back asking for the price of the fuel filter, they said it was in the gas tank and it's usually not serviced.
Old Feb 14, 2005 | 11:48 AM
chilifrost's Avatar
Could it be the alternator as someone had suggested.
Old Feb 14, 2005 | 12:09 PM
Dragging knees in
Nope. The alternator has nothing to do with starting the car. It's all on the starter and the battery power.
Have you gotten it scanned yet? I'm guessing that it's probably clogged fuel rails or insufficient EGR flow. Neither is devastating or anything like that, but in case it's something else, you should go get it scanned as soon as possible, and let us know what code it threw. It will be an alphanumeric code, starting with a P.
Old Feb 14, 2005 | 01:29 PM
BIG_KOUT's Avatar
anybody ever have this happen....... sometimes when I come to a complete stop after driving, my engine will kinda studder/gurgle trying to find the right idle rpm..... after about a second/second and a half everything evens out and it's good to go....
what's up with that!?
Old Feb 14, 2005 | 01:53 PM
phipark's Avatar
Not Asian
That's most likely the IAC valve and needs to be cleaned.
Old Feb 14, 2005 | 01:56 PM
BIG_KOUT's Avatar
what is the IAC valve? and what does it connect to, cuz I'm bringing my car to the dealer tongiht to have it checked. All info would be appreciated prior to going there
Old Feb 14, 2005 | 02:50 PM
4u2nv's Avatar
started happening to me last yr around 4 months ago.... i also have been driving my car then parked to it go eat.. and after.. it died up on me a few times b4 it started working normally again.. like the rpm will settle very low and engine juss shuts off.... does still happen to me every now and then but i juss close my eyes and pray. As for not driving the car enough.. i do think i drive it TO MUCH. lol... maybe its the fuel thing everyone is talking bout
Old Feb 14, 2005 | 03:29 PM
chilifrost's Avatar
Oh forgot to mention that the TCS light is also on.
Old Feb 14, 2005 | 03:34 PM
Faizalstar's Avatar
TLStar
same here, both TCS and check engine light comes on and then it goes away after a while. next time i'll try to make it to autozone to get it read.
Old Feb 14, 2005 | 04:37 PM
Dragging knees in
The codes should still be stored in the PCM, even if it went off on its own. You don't have to wait 'til the next time the MIL comes on to get it scanned.
BIG_KOUT --
My car does that at EVERY stop. It's annoying as hell, even worse when the HVAC is on. Last time, it went away after I replaced the O2 sensor. This time, I don't think that's it. I doubt it's the IACV, since my normal idle is perfectly smooth. Torque converter, maybe.
Old Feb 14, 2005 | 04:58 PM
bkzjimmy's Avatar
NiGhT rIdEr
this happens to me almost all the time....not when i first start it, only after i drive around 4 a while, shut it off and wait a few minutes then start it again...either it feels like its gunna stall or it does.....i usaully press the gas and get the rpm's up and then its fine.
Old Feb 14, 2005 | 06:24 PM
BIG_KOUT's Avatar
well, I brought my car into the dealer tonight and they will let me know what's up tommorow. Hope it's an easy fix. But still... less than 19k miles on the car and its doing this, wtf
Old Feb 14, 2005 | 07:34 PM
fsttyms1's Avatar
it may be EGR related.
Old Feb 15, 2005 | 10:42 AM
Elementz's Avatar
Exactly! Mine was doing the same shit a couple weeks ago. The way my dealer explained it was sometimes after you come to a stop and shut your car down, the IAC can get 'stuck' in the open position and cause your car to do that the next time you try and start it. Once it unsticks everything returns to normal.
They told me that since it only happened one time they were not going to replace it at this point, but it did scare the shit outta me when it happened. I thought it was something really serious but apparently its pretty common and not much to worry about.
Old Feb 15, 2005 | 12:23 PM
uncald4's Avatar
Former Sponsor
A jammed Intake Air Control Valve is kinda rare these days. I'd agree with the EGR Acura is well aware of all the EGR issues with the V6.
FUNNY STORY.... We took our CL down to South Tacoma Honda to see about trading it in on an '04 Civic. When we brought the sales person out to the CL to show him all the cool shit I've done to it........ It wouldn't start.
Just wouldn't freakin start. It would crank and crnk and crank and sputter. It took about 5 minutes before it actually would keep running. From that day this was a common issue with that car. POOP.
Old Feb 15, 2005 | 01:41 PM
Comet2404's Avatar
Flyin' and Drivin'
Happens to me everytime the car is warm.... I need a new EGR valve. When I start the car, as soon as it turns over, I give the gas a little punch.... and I said LITTLE.... so it barely revs just over 1,000RPMs.... then its fine.
Old Feb 15, 2005 | 02:31 PM
BIG_KOUT's Avatar
with my problem as stated above, the dealer said it was warped front rotors. But how could it be my rotors if the problem happens after I come to a stop
Old Feb 15, 2005 | 05:54 PM
fsttyms1's Avatar
its not
Old Feb 15, 2005 | 06:59 PM
BIG_KOUT's Avatar
yeah, wtf.... and when I got my car back, the dealer didn't put a piece of paper down on the floor mats and the guys boots must have been all muddy, and he got mud on the plastic kick panel next to the door. I can't wait till I get a service notice in the mail asking how they did.
pizokk1
Sep 17, 2015 09:29 AM
Billu99tl
Sep 13, 2015 11:30 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
