engine problem
engine problem
Today something strange happened to my car for the first time. I had been driving the car, stopped to buy some groceries when I came back I started up the car, it started to shake a bit then just turned off, did that about three times untill it finally stayed on, but the engine light came on. :wtf: Car is a 2000tl with 34,566 miles on it, new battery. :bigcry: Anybody know what might be the problem.
Hmm...Is that right??
i dont know.....changed the fuel filter yet?? even tho lo miles, maybe aged and clogged....also, if only weekend car, then sometimes when a car sits for a while, there are dirt particles and stuff that collects/settles in the tank and system that may cause "clogging" somewhere....i just feel like its fuel related...
if i couldn't spend any money, i would take it out and get on the highway and romp her up to about 90-100 or more *safely* and just drive her more....she needs to be used......thats if it was my car...what do I know?...
It could be just from the car sitting too long without being driven, especially if you live somewhere where it is cold right now. Go to Autozone/PepBoys and get a code diagnostic run and see if it is throwing any errors.
Dragging knees in
Get the code scanned, then go from there. AutoZone offers free scanning.
By the way, holy low miles on a 2000. Mine's an '03, and I have nearly identical mileage on her.
TLStar
my car has done that a good few times as well, thought it was the battery at first but it's not. i have over 70K and it does that, next time it happens just floor it a few times till it starts ok but usually once u can get it into drive w/o shutting off and start driving it's ok. if u do a search on this site you'll see others with similiar problems like this and some suggest that it may be a valve called "E--" something. should be covered on your warranty, if not i hear it's about $1000 to get fixed. haven't done anything with mine since it's out of warranty. good luck.
Sounds like it has to be someing along the "Not getting fuel" catagory. Check to see if it has a clogged fuel filter,, if not check the fuel pump. If none,, try reset the EMU and see if it does it again
TLStar
Dragging knees in
Could it be the alternator as someone had suggested.
Have you gotten it scanned yet? I'm guessing that it's probably clogged fuel rails or insufficient EGR flow. Neither is devastating or anything like that, but in case it's something else, you should go get it scanned as soon as possible, and let us know what code it threw. It will be an alphanumeric code, starting with a P.
anybody ever have this happen....... sometimes when I come to a complete stop after driving, my engine will kinda studder/gurgle trying to find the right idle rpm..... after about a second/second and a half everything evens out and it's good to go....
what's up with that!?
Not Asian
what is the IAC valve? and what does it connect to, cuz I'm bringing my car to the dealer tongiht to have it checked. All info would be appreciated prior to going there
started happening to me last yr around 4 months ago.... i also have been driving my car then parked to it go eat.. and after.. it died up on me a few times b4 it started working normally again.. like the rpm will settle very low and engine juss shuts off.... does still happen to me every now and then but i juss close my eyes and pray. As for not driving the car enough.. i do think i drive it TO MUCH. lol... maybe its the fuel thing everyone is talking bout
TLStar
Oh forgot to mention that the TCS light is also on.
Dragging knees in
Originally Posted by Faizalstar
same here, both TCS and check engine light comes on and then it goes away after a while. next time i'll try to make it to autozone to get it read.
BIG_KOUT --
My car does that at EVERY stop. It's annoying as hell, even worse when the HVAC is on. Last time, it went away after I replaced the O2 sensor. This time, I don't think that's it. I doubt it's the IACV, since my normal idle is perfectly smooth. Torque converter, maybe.
NiGhT rIdEr
well, I brought my car into the dealer tonight and they will let me know what's up tommorow. Hope it's an easy fix. But still... less than 19k miles on the car and its doing this, wtf
it may be EGR related.
Originally Posted by phipark
That's most likely the IAC valve and needs to be cleaned.
They told me that since it only happened one time they were not going to replace it at this point, but it did scare the shit outta me when it happened. I thought it was something really serious but apparently its pretty common and not much to worry about.
Former Sponsor
A jammed Intake Air Control Valve is kinda rare these days. I'd agree with the EGR Acura is well aware of all the EGR issues with the V6.
FUNNY STORY.... We took our CL down to South Tacoma Honda to see about trading it in on an '04 Civic. When we brought the sales person out to the CL to show him all the cool shit I've done to it........ It wouldn't start.
Just wouldn't freakin start. It would crank and crnk and crank and sputter. It took about 5 minutes before it actually would keep running. From that day this was a common issue with that car. POOP.
Flyin' and Drivin'
Happens to me everytime the car is warm.... I need a new EGR valve. When I start the car, as soon as it turns over, I give the gas a little punch.... and I said LITTLE.... so it barely revs just over 1,000RPMs.... then its fine.
with my problem as stated above, the dealer said it was warped front rotors. But how could it be my rotors if the problem happens after I come to a stop
yeah, wtf.... and when I got my car back, the dealer didn't put a piece of paper down on the floor mats and the guys boots must have been all muddy, and he got mud on the plastic kick panel next to the door. I can't wait till I get a service notice in the mail asking how they did.
Billu99tl
09-13-2015 11:30 AM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
