Engine oil level above normal level mark
Hi guys,
I checked my engine oil and it's above the upper level mark. It's just a little bit over the upper level mark on the oil dipstick. Should I be concern?
Originally Posted by EMC
Hi guys,
you should be fine. but if your worried about it take off teh oil filter, that will drain a small amout out. other wise there is no other way of draining a small amout out easy
I think taking off the oil filter is too messy. How about just losen up the oil nut just to let the the oil drip a little?
and just over the full line wont hurt. how did you check it? ittmay just have been a missreading? how much oil got put in the engine?
Yea, how much did you put in on the last change. I always put more then the recommended amount, I use a 5 gal jug of moblie 1 and always use the whole thing.
@ slide or die @
5GAL??? that's about 4 GAL more than recomended...doesnt our car require something like 4.6quarts (~gal and 1/8th)?
Having a bit more oil doesnt matter...just think about the older oil that's left when you drain it...having too much oil IS VERY BAD!! you'll notice when you leave a dark and opaque cape of brown fog behind you...eventually leading to messing up the engine.
HAHAH, no I meant 5 Quarts.
i also dump in 5 qts.
rockyboy
08-04-2024 10:35 AM
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
