Engine Oil?
Old Sep 10, 2008 | 01:09 AM
2000DEP's Avatar
School or Mods???
Engine Oil?
I'm going to start changing my own engine oil now(finally), but I need to know how much quarts is needed for one oil change?
and are all synthetic oils good for 7500 miles?
Old Sep 10, 2008 | 01:33 AM
LeeDan00's Avatar
Volks FTW!!!
search is your friend. you'll find tons of hits with this topic.
to answer your question, it's roughly 5 quarts and 7500 miles is your call. depends what kind of oil and how you drive. typically 7500 miles on fully synthetic will be fine.
Old Sep 10, 2008 | 06:32 AM
totaledTL's Avatar
Consult your owner's manual....
Old Sep 10, 2008 | 07:30 AM
fsttyms1's Avatar
4.7 most like my self just put the full 5 quarts in. Regular oil is good for 7500 miles. Look in the manual. Thats whats recommended by honda for oil change intervals. Syn will have added protection longer though.
Old Sep 10, 2008 | 11:35 AM
rob-2's Avatar
7500miles regular oil
7500-10K syn oil
15k Mobil 1 Extended performance http://www.mobiloil.com/USA-English/...rformance.aspx
I'm going to be switching over to Mobil 1 Extended Performance on my next oil change and after putting though some seafoam in my oil.
Old Sep 10, 2008 | 11:51 AM
BLADE RUNNER's Avatar
02 TLS SSM - Hi Oh Silvr!
I use 5 quarts, Penn syn oil, and change every 10K. No problems and less oil changing is helping the environment.
Old Sep 10, 2008 | 01:16 PM
AMGala's Avatar
Lamborghini Aventador FTW
I switched to Mobil 1 synthetic two oil changes ago, and I change every 7500 miles since most of my driving is short trips.
Old Sep 10, 2008 | 03:33 PM
02type-s's Avatar
-Arsenic-
I do Royal Purple every 4,000
Old Sep 10, 2008 | 03:47 PM
01tl4tl's Avatar
why so often on a good oil like rp??
are you in favor of generating waste oil, and lining someones pockets with profit?
The motorcycle is one thing- very different demands on the oil- but the TL- 7500 miles just like the oil reminder light or MID (gen3) says for it to be done
You have been here long enough to know fsttyms and the oil analysis he had done over 200,000 miles and the long intervals he went on regular- then synthetic oil
RP does great right to 7500- as most oils are designed to last just beyond that- to give a safety margin. Its the special additives that wear out- not the oil itself.
The oil makers know what the auto makers say on change interval~ and make a product to meet demand
Old Sep 10, 2008 | 03:51 PM
02type-s's Avatar
-Arsenic-
lol, I knew someone would be like "huh?!"
Sometimes I wait longer. Idk, I have 150k miles now, I guess I'm just a lil overly picky. I beleive I changed it at a little over 5k last time.
Old Sep 10, 2008 | 06:09 PM
derrick's Avatar
Now that distance between intervals as well as volume of oil required has been discussed ... next thing is weight of oil to use.
I think the manual states 5W-20 since helps with fuel economy, especially on cold starts. However, if you live in a warmer climate, then you're probably fine with 5W-20 but if you want a little more protection of the oil breaking down (ie keeping it in longer than 7500 miles if you use conventional oil), then you may want to consider 5W-30. I used to switch 5W-20 in the fall and 5W-30 in the spring but then I got lazy ... and went with whatever oil Costco had for Mobil1 ...
Old Sep 10, 2008 | 06:14 PM
russianDude's Avatar
Manual tells you 3750-7500 miles.
If you use synthetic this range can be possibly doubled.
I use Mobil1 EP, and because I only drive 6-7K miles (city driving mostly), I end up changing it once a year.
Old Sep 10, 2008 | 08:45 PM
01tl4tl's Avatar
hahahahahaha
You guys really need to learn what the oil ratings mean- here is a brief version:
W= WINTER= tested flowabilty/viscosity of the oil at 32 degree Farenheit
So super cold areas northern Canada--want 0-W,
medium winter users 5-W
and warm winters 10-W
Its got nothing to do with easier starts unless its 32 degrees F where you live-- today.
It was 60 overnight? or its been driven today? its at the warm viscosity when you start the engine.
The second number is flowabilty rate of the oil measured at 180 degrees- the normal operating temp of oil in modern engines is 180-220 F
Acura used 20 in gen3 because they needed to up the overall mileage of the comapny vehicles- (goggle CAFE fuel standards)
So each model was tweaked to get a little bit more, and they get to figure the numer of those cars sold and more bs--- to meet the govt requirements
IN essence 20 gives maybe .5 mpg more on the test procedure
BUT
It has less ~cushioning~ for the many metal parts that impact each other, and others rotate at thousands of times per minute
30 is the ~better for your engine~ way to go
Hope this helps understand the nature of the numbers game
Old Sep 10, 2008 | 08:54 PM
01tl4tl's Avatar
acura cared about passing a test standard
NOT
about keeping your engine protected from itself~
Old Sep 10, 2008 | 09:19 PM
Willie3.5's Avatar
SixSpeedDreamin'
I change my oil every 3,500 miles, but I'm thinking about switching to royal purple and doing my own oil changes. The Stealership can rip you off and Jiffy Lube<---they just suck, so much BS.
Old Sep 10, 2008 | 09:31 PM
rob-2's Avatar
It's a waste, acura says every 7500 miles and they know better. 3k and 3500 miles started from oil changers who wish to do more business.
Old Sep 10, 2008 | 09:34 PM
rob-2's Avatar
NOT
Not true Tom. If honda/acura cars started have motor problems because of their oil change schedule then consumers would stop buying.
If anything, honda/acura has some of the longest lasting motors in the business.
See the video on the link i provided, very interesting mobil 1 116k, all extended performance test on vegas taxis
Old Sep 10, 2008 | 09:45 PM
Owner manual says 3750 if you drive in sever conditions, and 7500 for normal conditions. If your driven is less than ideal, it should be less than 7500 miles.
Old Sep 10, 2008 | 09:51 PM
totaledTL's Avatar
Not so sure it's that cut & dried. 7500 highway miles is considerably different than say, 7500 mi. stop & go, many cold starts, contaminant build-up, moisture, etc.
Old Sep 10, 2008 | 09:56 PM
Bones45's Avatar
Long GuyIsland
this is probably debated on EVERY car forum and there is never a solid answer. I have had Hondas since 1992 and have always changed my oil every 3-4k, used Honda filters, and used Castrol.
I would be more worried about Hondas weakest point of the car, the paint and body work than any type of engine trouble from oil choices.
Just my .02
Old Sep 10, 2008 | 11:14 PM
2000DEP's Avatar
School or Mods???
Thanks guys for all the comments...it's a lot of info, but i get the idea
Old Sep 11, 2008 | 05:55 AM
01tl4tl's Avatar
the 20 is less protection for the engine internals rob- maybe not enough to make the engine die at 150, but you compare a gen2 to gen3 motor and the 30 car is going to have less impact wear
Ask your buddy at chevron which weight protects the engine better!!
Acura cared about making a standard- thats the simple truth of life
They use shit brake calipers when they could use better- but every penny counts....
Old Sep 11, 2008 | 06:21 AM
Luke7's Avatar
WNC Real Estate Sales99TL
Talking
Just my .02
Same here. My last 2 Hondas. 86 Prelude 299,998 miles on it when I sold it for $1000. My 91 Accord EX 304,000 on it = Sold it for $1200. No internal engine problems on either car. They ran great with that mileage on em. I use Fram / other brands since Honda / Acura has jacked up the price on their filters out the roof.
Old Sep 11, 2008 | 07:12 AM
fsttyms1's Avatar
And 99.9% of drivers here arent severe. My car idles most of the day, and i do a ton of stop and go. My oil samples have always shown great results at the 8, 10 and 15k marks. People have simply been brain washed by 3k commercials and oil change places/dealers telling them that it is necessary.
Old Sep 11, 2008 | 07:15 AM
fsttyms1's Avatar
So are you saying that the motor wouldnt have made it to the 300k mark doing 7500+ intervals???
Old Sep 11, 2008 | 08:05 AM
Bones45's Avatar
Long GuyIsland
agreed!!!
In fact.. my play car is a 87si prelude with 157k on it!! runs great! body? not so great!!
Old Sep 11, 2008 | 08:08 AM
Bones45's Avatar
Long GuyIsland
He mentioned nothing about oil change intervals. But I happen to think that whether you change oil at 3k or 7k, honda engines wont be affected. But thats just me. I still change my oil at 3-4k. Its a mental thing.
Old Sep 11, 2008 | 11:46 AM
rob-2's Avatar
Sorry I was refering to the 7500 change, we have miscommunicated. We agree, 5-30 should be used.
Old Sep 11, 2008 | 11:50 AM
rob-2's Avatar
Agreed.
Good friends of mine change their regular oil every 15K. One of them, a she, owned a Legend and put 350K on the motor with this frequency of oil changes.
I suspect it's more about other things, like how you drive and where you drive that matters.
I'm going to pull samples off the end of the 15K when ever that comes up and post them here for all to see.
Old Sep 11, 2008 | 01:48 PM
fsttyms1's Avatar
No but he quoted luke who said he changed his every 3-4k and said same here.
Old Sep 11, 2008 | 01:50 PM
fsttyms1's Avatar
a brain washed thing. Most people dont know any better and worry that their motor will blow up or wont last if they run longer.
Old Sep 11, 2008 | 01:51 PM
fsttyms1's Avatar
Agreed.
Ive got a oil change coming up, i too will post the results of my 15k run.
Old Sep 11, 2008 | 07:53 PM
OneCleanTL-S's Avatar
AZ Member.. :X
Cool
I use Mobil 1 syn 5W20 and a Mobil One M1-104 filter..... And change it out every 5K miles.
Old Sep 11, 2008 | 09:48 PM
02type-s's Avatar
-Arsenic-
So 5W30 RP would be better than the 5W20 RP I use now?
Old Dec 29, 2008 | 04:45 PM
DC3328's Avatar
Your Garage
so high mileage shouldn't affect the oil you buy? it seems like 5w-30 is the norm
ive got 153k and i live in miami, what do you guys think?
Old Dec 29, 2008 | 04:49 PM
rob-2's Avatar
use regular oil 5w-30 unless you burn alot due to a bad seal. Otherwise there is no point.
You shouldn't have any problems at 153K
Old Dec 29, 2008 | 08:43 PM
MOBB's Avatar
Hey you guys really want to change your oil every 5k, dont be like me with a pistion slap and a noisy engine.
Old Dec 29, 2008 | 10:42 PM
inyong1988's Avatar
It's more of how you take care of your car and how it's driven.
Old Dec 29, 2008 | 10:48 PM
rob-2's Avatar
car says every 7500 on regular oil... read the manual. Your motor issues aren't related to oil changes...
Old Dec 29, 2008 | 10:56 PM
inyong1988's Avatar
reading a manual is always good direction for maintain.
