Engine mount damper
Old Feb 17, 2010 | 06:10 PM
RC99TL's Avatar
Engine mount damper
So I just got my car back from the shop for: Ready?
New timing belt adjuster and pulleys, water pump, power steering pump, alternator and belts. I was looking under the hood when I got home and noticed a rubber block resting loose on the frame under the ABS pump. Then I saw the bracket on the end of the motor mount bolt where it came from. I never noticed this before and the shop manual does not show it. Do 99 TL's have a damper on this mount? If so it got damaged in reinstall. I did not notice any vibration - in fact the car felt smoother than ever. Should I replace it?
Old Feb 17, 2010 | 08:59 PM
fsttyms1's Avatar
There is a piece that im guessing got broken off during install I dnt see the need to install it if you dont see a difference with it.
#4 im guessing is what you are talking about.
50808-S0K-A80 SIDE ENGINE MOUNT DYNAMIC DAMPER,
Old Feb 17, 2010 | 09:29 PM
RC99TL's Avatar
Thumbs up
Sure enough thats the one.
Thanks for the info!
Old Feb 17, 2010 | 09:37 PM
RC99TL's Avatar
Does the weight go on the inside next to the inner rubber mount or outside of the aluminum bracket? hard to tell.
Old Feb 17, 2010 | 10:53 PM
phee's Avatar
I got the Shifts
its useless
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
