Engine cover push pin
I was reinstalling the smaller front engine cover this past weekend and the push pin on the left end of it popped out and flew to who knows where. Most likely in my lawn and then mowed over yesterday if that's the case. Do I have to order a complete new cover for 32 bucks? I'm not seeing that pin listed as a part by itself when I search. Any help is appreciated.
Which one? #11?
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/13s0k01_e0316.png)
#90603-P8A-A01
Under intake manifold cover
http://www.acuraautomotiveparts.org/...catdisplay.jsp
#90603-P8A-A01
MilwaukeeDave (05-02-2012)
as said above- any parts store carries a section of replacement plastic pins, door handles and knobs etc,,one maker is called HELP
some even have bins with every type connector known to car builders
I run without any of the engine covers now--lets heat escape a little better
The side plenums of the intake manifold polish up nice!
metal polish and a buffer on drill makes fast work of the plenums dullness
You can remove the plenums from manifold to clean inside the runners-
no, seafoam doesnt get this area very well- ok to reuse the gaskets
on the external plenum surface, test a small area with rag-polish- and hand power= to get an idea of the results
there are a few places some black spray paint would blend in well
rockyboy
08-04-2024 10:35 AM
cycdaniel
12-17-2019 10:58 AM
sockr1
10-01-2015 01:31 AM
Iakonafuji
09-21-2015 02:39 PM
