engine clicking noise when cold...
Old Feb 24, 2008 | 07:00 PM
1st timer's Avatar
UB6IB9
My mechanic told me my engine clicks when it's cold because I use synthetic oil.
How accurate is this?
Old Feb 24, 2008 | 09:43 PM
bibledriver's Avatar
Something is missing...my
Somehow, being that synthetics have been proven over and over, I would say that the better oil has nothing to do with the clicking. It is much more likely a little bit of valvetrain noise due to the engine temp, not oil. But, hey just my
Old Feb 24, 2008 | 11:42 PM
thisisnotdave's Avatar
Porkchop Sandwiches!
Yeah I dunno if our valvetrain is adjustable but if it is you may wana have yours checked out.
Old Feb 25, 2008 | 12:14 AM
Gfaze's Avatar
S E L L
First things first. Find another mechanic because this one is an idiot. The type of oil has nothing to do with your engine clicking. You most likely need your valves adjusted. Is the car around 100K miles? (Don't know the conversion to kilometers off hand) If it is, you're probably due for the 105K mile service which includes the timing belt, water pump, valve adjustment, spark plugs, etc. Once again, the fact that your oil is synthetic has nothing to do with the engine clicking.
Old Feb 25, 2008 | 07:24 AM
fsttyms1's Avatar
find another mechanic. He is an IDIOT.
(if anything it will quiet them down and it gives better protection in the cold)
2nd, Does the ticking go away shortly after or continue?
Old Feb 25, 2008 | 09:14 AM
1st timer's Avatar
UB6IB9
Yes it goes away when the engine is warm.
Old Feb 27, 2008 | 02:48 AM
Gfaze's Avatar
S E L L
Sounds like you might have sticky lifters. On your next oil change you should try one of those engine flush fluids. You add it to the oil and idle (DO NOT DRIVE) your car for about 5 minutes, turn it off and change the oil. This cleans out all kinds of gunk you might have in the valve train area (could be causing your lifters to stick) as well as the oil passage ways. A popular one used by many here is Seafoam, 1/3 can in the oil, 1/3 in the fuel, and the last 1/3 via vacuum line to clean out the combustion chamber but any engine flush should suffice.
Old Feb 27, 2008 | 06:05 AM
1st timer's Avatar
UB6IB9
i have tried one that I added to the gas tank,should I use seafoam in the oil only?
Old Feb 27, 2008 | 07:32 AM
fsttyms1's Avatar
Adding it to the fuel will not do it. It needs to be added to the oil. If that doesnt work maybe look into having the valves adjusted to see if that takes care of it.
Old Feb 27, 2008 | 10:00 AM
02type-s's Avatar
-Arsenic-
Your mechanic shouldn't be allowed to touch your car if he thought synthetic oil made your motor tick.
Old Feb 27, 2008 | 08:54 PM
eleventure's Avatar
the noise might be coming from one of your belt tensioners.
Old Feb 28, 2008 | 08:27 AM
Adjust the valves
Feb 25, 2020 09:57 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
