engine clicking noise when cold...
Somehow, being that synthetics have been proven over and over, I would say that the better oil has nothing to do with the clicking. It is much more likely a little bit of valvetrain noise due to the engine temp, not oil. But, hey just my
Originally Posted by 1st timer
My mechanic told me my engine clicks when it's cold because I use synthetic oil.
How accurate is this?
First things first. Find another mechanic because this one is an idiot.
The type of oil has nothing to do with your engine clicking. You most likely need your valves adjusted. Is the car around 100K miles? (Don't know the conversion to kilometers off hand) If it is, you're probably due for the 105K mile service which includes the timing belt, water pump, valve adjustment, spark plugs, etc. Once again, the fact that your oil is synthetic has nothing to do with the engine clicking.
Yes it goes away when the engine is warm.
i have tried one that I added to the gas tank,should I use seafoam in the oil only?
Originally Posted by fsttyms1
Adding it to the fuel will not do it. It needs to be added to the oil. If that doesnt work maybe look into having the valves adjusted to see if that takes care of it.
Adjust the valves
Mike Bertram
Sep 10, 2015 09:27 AM
I dunno if our valvetrain is adjustable but if it is you may wana have yours checked out.
