Engine cleaning
Old Jul 3, 2002 | 11:47 PM
smoothnyc's Avatar
Question Engine cleaning
i want to get my engine looking shiney like the first day i got it, 3-22-02 03 S-navi. Can anyone recommend a method of cleaning or even comment on how safe engine cleaning is. I would love to hear opinions before i clean the engine cause i dont wanna hurt my car....thanks
Old Jul 4, 2002 | 02:32 AM
STi's Avatar
STi
you could use the Meguiar's all surface cleaner
it's a lot of work though
Old Jul 5, 2002 | 03:56 PM
NormRD's Avatar
4th Gear
Many people use simple green. I dilute it in water 1:1, then just spray it everywhere inside. Use a cloth to wipe off the really bad parts, then just rinse with a hose(not pressurised, just coming out with no attachment).
Old Jul 5, 2002 | 06:01 PM
NsX Pilot's Avatar
simple green or dawn works for me and i use a 1300 psi pressure washer to clean it off........first i suggest a 50/50 solution mix of either one you choose and soak the engine with it ...if you like you can use a brush ....if u have a cai or other type of air intake with exposed filter i suggest u cover that. Ohh and make sure that your engine is not hott when u do this i suggest you do it after the car has sat for a few hours. you can run your car after to dry the engine or just let it sit which ever u like....i hope this has been helpful...i do this same routine for the rims.
Old Jul 5, 2002 | 08:36 PM
vojm's Avatar
you just let water drip everywhere and it is ok?
oyayjoe
Jan 1, 2019 10:17 PM
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
Sep 14, 2015 10:09 PM
