E-Brake light
E-Brake light
I've noticed lately that in the mornings, or when it's cold (Florida cold, <50 degrees) out, my E-brake light will stay on for quite some time. I never use the e-brake, so I know that it's never on. My integra used to do the same thing on cold mornings too. Is this something I should worry about? It doesn't seem to be causing any problems.
Its not the E-Brake light meaning something is wrong with the e-brake. Take teh brake fluid cap off and check to make sure its at the proper fluid level. Also clean the part where the brake fluid float slides up and down to make sure its not getting stuck causing the light to come on
If you are low on brake fluid, consider looking at the brake pads for low remaining life, if they are down, the fluid goes into the caliper further- making the res low so you know it!
ah, that makes sense. Is there any reason that the light would turn off after a while? Does the fluid expand enough when it's heated that the float slides up enough to turn off the light?
My car also used to do that in the cold. Last winter sometimes I would drive and and it would come on when braking or other times it would come steady for a few minutes. This winter it hasnt done it at all and now it diffenently wont I dont think because now we cleaned out the extra spot in the garage and my car is parked in there. However I know I got the brakes and rotors changed on 12/20 and it has been outside and still nothing. I think maybe my sensor was just stuck and now its fine.
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
