Dual battery and or HO alternator
Subscribe
Mar 3, 2008 | 12:23 PM
I am looking to put a dual battery system in my 99 and was wondering if anyone had done this before. I was having trouble on placing the second battery, as I would like to keep it in the engine bay. I also was wondering where I could find a good High-output alternator.
Reply 0
Mar 3, 2008 | 04:28 PM
why? big time audio im guessing?
Reply 0
Mar 5, 2008 | 04:48 PM
yup. 600W amp and JL 10w2 is just the beginning and they make my lights dim.
Reply 0
Mar 5, 2008 | 06:17 PM
Yeah alternating your hos is always a good idea. Sorry couldnt resist.
Reply 0
Mar 5, 2008 | 06:23 PM
Quote: yup. 600W amp and JL 10w2 is just the beginning and they make my lights dim.
I'm running a 2000 watt system, with no caps, stock battery and alt., absolutely no issues. Maybe 05 TL electrical is more robust. If anything you could probably get away with a single stinger or kinetics (sp?) battery and "maybe" a cap...I think 2 batteries is overkill
Reply 0
Mar 5, 2008 | 07:18 PM
Quote: I am looking to put a dual battery system in my 99 and was wondering if anyone had done this before. I was having trouble on placing the second battery, as I would like to keep it in the engine bay. I also was wondering where I could find a good High-output alternator.
There is no reason to add a second battery unless you are planning on running your system for extended periods with the car off.
A ho alternator along with the "big three" upgrade is your best bet. Caps are a bandaid to a weak electrical system.
<Worked in higher end car audio for 3 years+
Reply 0
Mar 6, 2008 | 05:26 PM
Quote: There is no reason to add a second battery unless you are planning on running your system for extended periods with the car off.
what he said ^^
what im thinking is that your battery is probably just shot.. or not good enough.
Get a good battery and do the big-3, if that doesnt fix your problem, then replace the alternator with a HO one.
Dual battery is totally, i mean REALLY unecessary in your case.
Reply 0
Mar 6, 2008 | 06:33 PM
lol.. im running a 600watt amp as well with no problems with all stock components. you only need to step up to a bigger alternator when your pushing 1000 + watts of RMS power.. and if someone tells you to buy a cap, just use that cap to smack them upside the head..they are useless.
Reply 0
Mar 6, 2008 | 07:11 PM
my sub amp is 1250 and speakers are 700.... and it sometimes dims my lights, barely now that i put in my cap.... but once i do the big three and a yellow top im sure ill be ok
you should be more than alright. do the big three or maybe your amp is really inefficient
Reply 0
Mar 9, 2008 | 10:53 AM
Quote: my sub amp is 1250 and speakers are 700.... and it sometimes dims my lights, barely now that i put in my cap.... but once i do the big three and a yellow top im sure ill be ok
What is the big three?
Reply 0
Mar 9, 2008 | 11:12 AM
i was wondering if the ground placement had anything to do with it.
i have the lights dimming problem in my car too.
i have a jl 500/1 amp and 2 10" kicker comp vr subs.
no cap, stock alternator, and a optima red top battery.
Reply 0
Subscribe
