drl's stop working
Old Oct 8, 2009 | 08:52 AM
  #41
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
you should come to the meets too man i wanna see your ride... your car looks a million times better then mine im pretty much stock
Old Sep 16, 2010 | 03:19 PM
  #42
kenchau's Avatar
Hate to bump an old thread, but forgive me if this is a dumb question. If I pull out the DRL control module to do the fix, as explained in the link provided earlier, can I still drive my car without it plugged back in? If so, will I still be able to use the regular headlights? Thanks!
Originally Posted by JoeTL99
The drl control module stops working usually because the solder joints go bad. I fixed mine by re-soldering the joints. This link was very helpful http://www.nyx.net/~smanley/hondadrlfix/
Old Dec 30, 2010 | 11:13 AM
  #43
Jchick's Avatar
I'm having the same issue - driver side high beam not working and the DRL not working. Bulb tests good. (TL came from Canada). Going to try to find that module and check the solder joints. This link seems to be active still:
Thanks!
DG
Old Dec 30, 2010 | 12:16 PM
  #44
Jchick's Avatar
...and 1/2 hour later:
Behold, that was the problem. Soldered all of the relay joints and problem solved.
DG
Old Dec 30, 2010 | 01:48 PM
  #45
kdawg8526's Avatar
its good u repaired that because that module is pretty pricey it costs 200 bucks at the stealership.
Old Dec 16, 2020 | 03:05 PM
  #46
YVRDave's Avatar
3rd Gear
Thumbs up
The drl control module stops working usually because the solder joints go bad. I fixed mine by re-soldering the joints. This link was very helpful Honda Accord DRL Relay Repair HOWTO
This worked as advertised for me. My DRL lights wouldn't work, Hi beams and the rest did. Re-did the poor solder joints on the two relays contacts in the DRL module exactly as shown in the referred link. Thank you.
Old Dec 28, 2020 | 05:14 PM
  #47
Imre Molnar's Avatar
Hope it's gonna help
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
