DRL Issue
Old Jan 30, 2022 | 01:17 AM
brianmystery's Avatar
DRL Issue
Hi everyone,
I need your advice about the daytime running lights. The DRL on dashboard lights up. I already bought new bulb and repaired it with the old one on the driver side but it wasn’t on. Then, I decided to switch it with the current one on the passenger side. The old bulb on the driver side turned on when i plugged it in on passenger side. I came to conclusion the bulb is not the cause. One more thing, when i turn on high beam, only the one on passenger side works. Anyone has experienced this pls give me some advice.
Thank you for reading my post.
Old Jan 30, 2022 | 12:45 PM
Pair of TLs's Avatar
Check your ground wires...
Old Feb 8, 2022 | 01:38 PM
x Hades Stamps's Avatar
I would recommend inspecting the DRL module‐‐This was around the time they started using lead free solder, and as such, experience with it, even among manufacturers, was limited, and formulations hadn't had all of the kinks worked out. It is very possible that yours is defective. That's what the problem with ours was (We don't live in Canada, but ours is the Canadian version‐‐The previous owner moved here from Canada)
New2meTL88
Mar 26, 2019 01:41 PM
kostakong
Jan 11, 2017 06:54 PM
tongr888
Oct 28, 2011 06:29 AM
Toronto_99_3.2tl
Mar 26, 2008 10:28 PM
