Downshift or………?
Old Dec 5, 2006 | 05:32 PM
Acura_TL's Avatar
Downshift or………?
When I’m in manual mode and in 5th gear, if I’m driving at a constant speed, then open it up past about half way, the RPM’s jump up about 750 rpm (say I’m at 2k, floor it, now I’m almost at 3k), just like it downshifted, however it didn’t downshift because the display still says 5th, and if I then manually downshift to 4th the rpm’s will jump up even more (like they should).
I guess my question is…..What is this jump in RPM that I’m seeing without ever shifting? Is my tranny going bad, or is this just an Acura thing?
If all Acura’s do this, sorry for the dumb question, but this is my first Acura.
Old Dec 5, 2006 | 05:45 PM
bkzjimmy's Avatar
NiGhT rIdEr
wow, what a question. everytime u press the gas the rpms raise to give the car more power to accelerate. if they didnt jump that would be a problem.
Old Dec 5, 2006 | 05:55 PM
fsttyms1's Avatar
thats the torque converter unlocking
Old Dec 5, 2006 | 06:09 PM
Acura_TL's Avatar
bkzJimmy - normally a car doesn't jump up almost 1k rpm's instantly before actually accelerating(at least no car I've ever driven), I'm talking about cruising at 70 mph at about 2k rpm's, I hit the gas, the rpm's jump up to 2750 before the car starts to accelerate, without it actually downshifting. I've never had a car that did that before.
fsttyms1 - So this is just the torque converter unlocking, and is normal for the TL?
Old Dec 5, 2006 | 06:11 PM
Shaqs2002TLS's Avatar
it's just you pushing on the gas. Even if you were in normal mode and in fifth gear and you pushed the gas (not so hard where it'll downshift to 4th) then your RPM would increase due to the depression of the gas pedal.
Old Dec 5, 2006 | 07:05 PM
jayunsplanet's Avatar
Some of that could just be tranny lag. You don't get instant power...
Old Dec 5, 2006 | 07:40 PM
type-s09's Avatar
13.2@ 107 on Street tires
4th gear does it..along with 3rd...its just the torque converter...try this next time you are accelerating...goin about 40 mph in 3rd give about 25% throttle...then once at about 45mph...give 100% throttle..the rpms will jump about 750-1000 rpms...
Old Dec 5, 2006 | 08:20 PM
Fredo0709's Avatar
I believe that's called "tranny lag". When you depress the gas pedal, the engine speeds up and pumps more fluid into the torque converter to transfer the increased torque to the wheels. The time between the engine revving up and the actual power transfer through the torque converter is the torque converter's turbine spinning up. To improve efficiency, modern torque converters "lock-up" and both sides of the torque converter spin at the same speed. This usually happens when you're at speed and not accelerating. In order to accelerate, the torque converter must first unlock.
Here's an interesting read: http://auto.howstuffworks.com/torque-converter.htm
Old Dec 5, 2006 | 10:39 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
It's the torque converter unlocking, that's all. There is no grand theory to this. It's normal function, happens in all automatics I've driven that I can remember.
Old Dec 6, 2006 | 01:51 PM
Acura_TL's Avatar
I guess in previous cars I always just thought it was downshifting, but now I know it was the torque converter.
Thanks for all the answers guys.
Old Dec 6, 2006 | 09:01 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
it most likely was a downshift in the old car. when you are in ss it doesnt automatically downshift. so you notice things like that.
Old Dec 7, 2006 | 07:46 AM
snowman81's Avatar
Sippy Cup (x2)
It happens in SS mode because 5th gear is an overdrive. The RPM's will still jump up because you won't be able to accelerate in 5th gear. It only does it when you are in 5th gear if you are in SS mode I believe.
Old Dec 9, 2006 | 03:19 AM
GQ_22's Avatar
The penguins are crazy
It does it in my 4th gear (99) tl also, on a nearly brand new transmission (8k on it or so). Torque converter unlocking like they all said.... Damn I miss having a manual tranny
Mike Pilipenko
Mar 26, 2024 09:21 PM
kixo
Sep 5, 2015 08:54 PM
mrlemonjello
Sep 1, 2015 08:52 PM
Crazy Bimmer
May 2, 2010 06:34 PM
Universe93B
Mar 28, 2001 08:43 PM
