door security led...HELP
Old Feb 15, 2004 | 07:23 PM
after changing the red security led into blue ones now its not working anymore even putting back the factory led try turning it around and still it's not working anymore.Can u reset it after u disconnect it .please help....TY
Old Feb 15, 2004 | 10:07 PM
ou sig's Avatar
Boomer SOONER
I remember someone else had a similar problem. He also said that his Auto window down didnt work. The reply was to lower the window down and keep holding the down button for 5 - 10 sec. and the raise the window and do the same.
The person said that his window worked, but he never said anything else about the light....dont know if this will help, but I would try it!!
Good luck
Old Feb 16, 2004 | 09:03 AM
Tatewaki's Avatar
It's just a simple LED. Did you cut and solder the LED on it, or did you de-solder it from the PCB? Check your soldering job to make sure you got good connection. Check the plugs where it connects to within the door panel
Old Feb 16, 2004 | 09:39 AM
i remove the factory LED and solder a new one on the PCB.I'm sure about the soldering cause i'm doing soldering micro parts for 6yrs. already.or maybe could i replace that one with some eurolites , the one that they sell in circuit city.
Old Feb 16, 2004 | 02:45 PM
Hello all:
Possibility that heat may destroy LED during soldering operation?
Bryan, have you try to apply a 1.5 volt battery to the LED and check them out, watch out for the polarity of the LED. If the LED lite up then you might have problem in the alarm circuit. Next step, use a DMM and measured the voltage drop across the LED when the system is armed. It should have a 0.7 Vdc for an LED.
HTH
DavidTLS
Old Feb 16, 2004 | 06:36 PM
thanx David,ok for example i burn the alarm circuit. can i get a replacement from the dealer ? or can i put some aftermarket LED,s
Old Feb 17, 2004 | 01:44 PM
Hello all:
Bryant, if the alarm unit is messed up then I would take the vehicle to the dealer, and claimed under the warranty.
Did you verified to see if the Factory LED and the Blue LED working?
The LED required approximately 0.7 Vdc drop across it terminals.
Re-install Factory LED, and have dealer change out new alarm unit and goes from there.
BTW, I am planning to added another LED on the steering column by running in series with the factory LED.
HTH
good luck
Old Feb 17, 2004 | 06:13 PM
thanks for the reply David,maybe i'll it to the dealer.and keep me posted on ur LED mod cause i'm planning to do it too....
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
