door lock knob question
OK, I am not a complete idiot, but . . . has anybody tried to replace their plastic door lock knobs. I took one out and now I am having problems getting it to "catch" the threads to put back on. Is there a trick to it or something?
it's a self tapping screw. I got into the same problem before. all I did is to press down the lock tab and lower the screw inside door panel. the screw will center itself and insert the door knob inside (be careful not to drop inside the door panel), then flip the lock tab up; the screw will find its way into the knob hole. turn the know slowly and let the screw to find the knob's orginal thread. Do not rethread the knob, it will become loose.
I just had the same problem. I had to open the door panel and hold the lock in place with a screwdriver. The door panel is very easy to open. Start from the lower right and work your way up. The previous post seems easier but I did not have luck with trying to center the self tapping screw.
Originally Posted by jpadilla
they look out of place ... and draw a lot of attention to them ... "Hey look at my door lock knobs". I perfer the original ones ... more toned down.
jpadilla :
To each their own. It's unfortunate you'll probably never see them in person...however they blend in perfectly with the miscellaneous chrome/alunimum trimmings we have...especially with the black interior. I doubt this would ever look right in a tan interior. Plus I have a whole theme going on (aluminum pedals+shift knob+turn signal rings+interior badging).
Keep in mind all this was done for a reason...not just for aesthetics. I beleive the only mod I've done to my car that wasn't fuctional is the bodykit.
EDIT: and the turn signal rings.
it should work, it works for me (when plumbing!)
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
