doing my own oil changes..
#242
higher overhead means higher prices- be it the labor rate or the parts price- someone is paying for that nice showroom and waiting lounge
You didnt think free loaner cars were really free did you>
#243
Prick of the month
I just looked at the statement from the last time I had the dealer change my oil(which may in fact be the last time they ever change it) and they have the filter listed at $7.90, so someone is screwing you and not in the good way...
#244
I did a oil change on my friends 2005 Accord V6 6sp this weekend. I usually use the rhino ramps. His car is also lowered like mine but he has the Kamanari body kit and it took us 1.5 hours to figure out a way to jack up the car. We went ahead and bought the pro jack. but it still would not slid under the car. After many attempts we got it at a angle and put some Fresh Royal Purple and Mobil 1 Filter.
#246
So I must admit I jumped on the Royal Purple bandwagon. I really dont see that big of a differ. From hangout on bobistheoilguy.com, I think i am going to stick to Valvoline Synpower. I have synpower in our RSX and TSX, and have valvoline maxlife in our suburban.
Anyone else using Valvoline Synpower?
#247
how much does it cost youll doing it ur self with good ffilter and with good synthetic oil?? my dad puts normal oil but i dont like that crap in my car so i wana switch over.. u can do that rite??
#248
Prick of the month
I spent $28 at Wal-Mart for a 5 quart jug of Mobil 1 Extended Performance and $6 on a filter, you can spend $10-15 on a filter, it's your choice. So, about $35, still cheaper than the dealer and it doesn't take long.
#249
#250
Read back thru the thread and see horror stories over oil plugs way beyond tight- that crush washer crushes for a reason and seals at the right torque, stripped threads, loose plugs, no oil added and much more have occured at shops
Many of us have loyalty to a brand oil or filter, and prefer our filter contain oil before installation, and not dry start the engine as most oil change places do
Or you want a sample of your oil for sprectrum analysis www.blackstone-labs.com
Easy to add seafoam to crankcase before change at home too
Go to the wash and wax section in Off Topic- the dangers of letting others wash your car go from scratches to rim damage
Get out the claybar and have a good time making your car nicer than its ever looked
Maybe you like to look over the car underneath for damage or wear items
Know that your tire pressure was set correctly
General satisfaction of working on ones car
Anyone else want to chime in?
#252
California and many states have a free Oil recycling program that all parts stores that sell oil must take used oil (reasonable amount to what you purchased) and the quickie change places also have to accept oil from you- as long as its not cross contaminated with water or any other oils, in a sealed jug- bring it in and they empty it for you!!
so, FREE would be the answer to how much to dispose of the oil
#253
you can go back and forth all you like- the engine wont care
#255
Even the dino will go well over 3k but its free so ....
#260
Originally Posted by orgnlprankster7
well im going to change my oil myself for the first time tomrow, 5w30 penz plat with mobile 1 filter. can i just pick up a new drainplug washer at autozone?
#261
I replaced the entire drain plug-came with new washer ~$2.50
That way I had one I knew that was never over-torqued
If your car ever saw a quick change place- replace the entire plug and washer
Spec is 29 foot pounds
With the leverage they get standing under the car- way past that--
is what you end up with!
#263
some old schoolers or uneducated youth follow the 3k method
The rest of us vary between 5000-7500, when the service minder light comes on
and 10k+ for some synthetic users with lab analysis of condition part way thru useage
#265
I guess I'm gonna go do me my oil change soon also. Mobile 1 it is, even though my buddy suggested me Castro. I currently have Mobile 1 in my car now and it seems fine to me
#266
Make sure to get the Mobil1 High Mileage FULLY synthetic- thats the old formula mobil1 that is preferred
grab a can of seafoam and do treatment-
or some basic $2 engine oil cleaner, run it 5 minutes then do the oil change
#267
Rich
I use it on my camaro and my hayabusa.
But I use castrol on my wife tl and my truck. (cheaper)
Castrol is pretty good oil for the money.
Cuz my truck has 150K (hard mileage/pulling the trailer for my camaro) and still runs good. (knock on the woods)
#268
Dude whatever you do, DO NOT USE THE PURALATOR OIL FILTER!!!... I used to work at advance auto parts and thats the cheapest filter they have in stock ... I would go with the K&N... It's a little bit more expensive but you get what you pay for...
#272
Lamborghini Aventador FTW
#274
Originally Posted by socko
I recommend the Fumoto oil plug valve. It makes draining the oil simple.
The Fumoto drain valve is a great product. I installed one on my TL last year and it really makes draining easy. As an added bonus, I no longer have to fish the drain plug out of the oil filled drain pan.
#275
Your first time? an oil change virgin!!!- wow- if only we had only known we would have gotten you a present of a 3 foot breaker bar.
Most oil changes places tighten the plug way past spec and its a real pain to remove.
AMG:
I bought the entire plug and washer unit in 1 bag at zone.
Their washer was mystery plastic, while the CORRECT washer from dealer is copper, so grab a few while you drop by acura too.
When I next changed my oil- the washer had a very odd and disconcerting melt? hole in it, not at the edge where it would leak, but enough to merit another trip for a copper washer.
Once the plug has been overtorqued- and you can be certain it has every time until YOU do it, it stresses the metal= no good anymore
AMG:
#276
They make plastic jugs for oil draining, self contained- no spills,
and no way for the plug to fall in.
and often FREE at State recycling places. Our local oil and hazmat dropoff will give you 1 when you bring in anything.
Its the beginning of the year when everyones stash comes in- make a call
Now I keep a spare plug with washer all ready to go. Let the hot one lay in the catch can and install a nice clean cold one
#277
AMG:
AMG:
#278
With proper torque- there is no reason for it to suffer any wear issue, so the only problem would be if you grabbed it with vise grips and trashed the head
While we have different taste in light colors, I am willing to believe you have always done perfect 29 lbs- torque wrench or not
200k miles, that was what? 15 oil changes for you
#279
Something like that.
